Author Topic: Wing mirror not dipping  (Read 6956 times)
Offline CookieMonsterGTi
« on: 13 November 2019, 20:38 »
Hi.
I have ticked the box in the car settings and have my mirror position set to the passenger mirror but it doesn't dip when going in to reverse.
*Its a MY20 TCR if it makes any difference...
Any ideas on what the issue is, is there maybe a reset I can do or will it be a trip to the dealers?
Pure Grey GTI TCR 5 Door DSG
19" 'Reifnitz' Alloys Including DCC
Climate Windscreen
Panoramic Sunroof
90% Rear Tinted Glass
Offline wantmygti
Re: Wing mirror not dipping
« Reply #1 on: 13 November 2019, 20:49 »
Move adjustment mirror selector to R, try again....
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline wantmygti
« Reply #2 on: 13 November 2019, 20:52 »
I think I have skim read that a bit quick, you might have tried the mirror selector already.
Offline Yusee
« Reply #3 on: 13 November 2019, 21:02 »
You have to select “L” for the nearside mirror to dip on reverse
« Reply #4 on: 13 November 2019, 21:08 »
Yep ‘L’ is selected.
The mirror works in so much as I can control it’s position, just that it doesn’t do when selecting reverse. For this reason I thought it may be software related or me doing something wrong. Thought there may be some kind of reset.
Climate Windscreen
Panoramic Sunroof
Offline Yusee
« Reply #5 on: 13 November 2019, 21:24 »
Ah yes, you did say.
It may be that you haven’t saved the exterior mirror setting for reversing-
The handbook takes you through the steps-
Select reverse then adjust the mirror to get a god kerb view, then put the gearbox back into neutral and switch off engine
That should do it, if you haven’t already done?
Offline Yusee
« Reply #6 on: 13 November 2019, 21:27 »
A “ good” kerb view!
« Reply #7 on: 13 November 2019, 22:47 »
Thanks. Didn’t realise that would be a thing as previous car just angled down to a fixed point with no adjustment.
My fault for not RTFM  :grin:
Will try this out tomorrow. Appreciate the help.
Climate Windscreen
Panoramic Sunroof
Offline rajb
« Reply #8 on: 13 November 2019, 22:59 »
Yeah as Yusee mentioned, I had this when I accidentally reset the mirror when in reverse to normal driving position so in reverse it stayed in position.  You have to just manoeuvre the mirror into where you want it when the selector is pointed at Last AMD the car is in reverse. The mirror memorises that position then for when selecting reverse.
Offline Hertsman
« Reply #9 on: 14 November 2019, 09:20 »
Had to do the same on my TCR, thought it was me until realised had to set up the kerb view - imagine its done in PDI usually hence why it usually just works when you receive.
On subject of PDI did provide some feedback as they obviously tested the passenger air bag disabling which is important to do, but never turned it back on!
Noticed immediately as very used to the lights in the MK 7 and the warning light remained on instead of going out after a set period and went to passenger side and turned on with the key.
But in essence they delivered a car without an air bag functioning
Present - Cupra Terramar 272BHP VZ1 - Fjord Blue
- 2nd car: 2019 Golf R DSG Pure White 19" Black Pretoria, Privacy Glass, Rear View Camera, Dynaudio, Keyless
- 2022 BMW 128Ti Alpine White
- 2019 Pure Grey GTI TCR 5 Door DSG Reifinitz Wheel DCC Climate Screen 90% Tint
- 2016 Lapiz Blue Golf R 5 Door DSG Pretoria DCC
- 2013 Pure White GTD 5 Door DSG DCC
