Author Topic: Moisture in the headlight... FIXED  (Read 27554 times)
Offline Jim_mk7.5
« on: 30 September 2019, 18:31 »
Hi all, thoughts on whether this will naturally dry out or needs a trip to the dealer?
Went unavoidably through a big flood on the passenger side yesterday and looks like it’s more than the usual bit of steaming up.
« Last Edit: 12 November 2019, 20:00 by Jim_mk7.5 »
NOW - 330e M Sport
Offline Carbon VW
Re: Moisture in the headlight...
« Reply #1 on: 30 September 2019, 18:47 »
If that was my car I’d leave the car ticking over for a few hours with full beams on to try and create some heat to dry it out.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline Jim_mk7.5
« Reply #2 on: 30 September 2019, 18:50 »
Not a bad idea although not sure how much heat the LEDs create?
Plus don’t have anywhere at home or work that would be safe to leave the car running.
NOW - 330e M Sport
Offline Ryan90GTI
« Reply #3 on: 30 September 2019, 18:54 »
Looks worse than the normal bit of condensation. Does it affect the beam pattern at all?
Offline Jim_mk7.5
« Reply #4 on: 30 September 2019, 19:07 »
Not been out at night to test that. It is very wet inside so thinking it might not just dry out.
NOW - 330e M Sport
Offline Carbon VW
« Reply #5 on: 30 September 2019, 19:26 »
Go for a long drive or sit outside in it for an hour or 2 ! Either that or go to the stealers. The main beam will build up heat over time and reduce/eliminate your problem. I’m speaking from experience. The lamps are vented and will clear up over time
Offline Talk-torque
« Reply #6 on: 30 September 2019, 20:36 »
You could try gently heating the front, with a hair dryer, to drive the moisture out through the openings around the bulb fittings in the back. Not sure what else a dealer workshop could do, short of removing the headlamp, stripping it and then drying it with heat.
Roger.
Offline monkeyhanger
« Reply #7 on: 30 September 2019, 20:41 »
Experience of LED headlamps?.Halogens and Xenons kick out some heat to evaporate the moisture, LEDs are running very cool - the main reason they are so energy efficient - almost all electrical input is converted into light and not heat. You're using only 40% of the energy requirements of a halogen bulb and 60% of the Xenon bull's requirements. They only put out about 20% of the heat of halogen/Xenon - you'll be driving a hell of a lot longer to evaporate the condensed water vapour.
Offline Carbon VW
« Reply #8 on: 30 September 2019, 21:31 »
Yes Monkey,  speaking from experience. I have worked with LED technology when you were still driving around in halogens. I work with IALA who specialize in buoyage in the maritime safety industry at sea and my area of experience is in LED technology so yes I would hope I know what I am talking. LED’s encapsulated in that lens and housing will indeed create heat which will eliminate that condensation over time, certainly if the OP uses his main beam/dims all the time whilst driving until it disappears completely. I won’t get into heat specifics with you as it’s not the place to swing ones balls around the place.
Offline Adam T7
« Reply #9 on: 01 October 2019, 12:07 »
That does look a significant amount of moisture - been doing a lot of driving in the wet / through puddles? - I get some along the bottom of the light - which does dry out - assuming by combination of residual engine warmth and whatever heat the LEDS put out.
