Author Topic: wiper blade trimmer  (Read 2909 times)
Offline spiked71
wiper blade trimmer
« on: 21 August 2019, 15:26 »
anyone tried the ecocut wiper blade trimmer?
just had mine delivered today, seems like a good tool if it works.
blades should last 3 times longer it says...
2017 clubsport ed 40    19" bresicas, pure white, 5 door, dynaudio, rear view camera, recaro buckets, winter pack.
Offline rwleigh
  • Richard.
Re: wiper blade trimmer
« Reply #1 on: 22 August 2019, 00:56 »
I have, works as described. My advice is to take the blades off and clean them first with soapy water, then while they're still wet and slippery do a cut. You get a good clean trim like that...
Golf GTI CS40 #010 | Manual | 5 door | Pure White | Car-Net | 90% tints | Winter Pack | REVO stage 1
Offline spiked71
« Reply #2 on: 22 August 2019, 07:37 »
thanks for the tips, did you have any bad cuts? does it ruin the wiper if you do??
Offline rwleigh
  • Richard.
« Reply #3 on: 22 August 2019, 09:26 »
Not personally but I can see how people would if the blades weren't clean and slightly lubricated as suggested above. You just need one good smooth run down each blade.
Offline spiked71
« Reply #4 on: 22 August 2019, 18:53 »
wot a handy little tool.. worked a treat, nice even clean cut all the way along, bit fiddly
to get started, but once i could get a grip of the wiper behind the tool it flew down the cut.
cheaper than replacing the wipers and get to cut twice on each wiper,so well worth the 12 quid
in my opinion. :smiley:
Offline rwleigh
  • Richard.
« Reply #5 on: 23 August 2019, 01:17 »
I concur...
