Author Topic: GTi - Coolant light issue  (Read 1978 times)
Offline GTI2016
« on: 10 August 2019, 12:05 »
Hi All,
I've been having an intermittent coolant issue recently with the MK7 GTi PP.
After 30 mins or so of driving the red coolant light comes on. I let pressure out of the system by opening the cap and the coolant level comes back to normal; its like pressure is builds up forcing down the coolant level.
Has anyone come across this before and found the cause?
Any thoughts would be great!
Offline wantmygti
Re: GTi - Coolant light issue
« Reply #1 on: 10 August 2019, 13:29 »
Bet it’s the usual water pump / thermostat and housing issue.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Ginagee
« Reply #2 on: 12 August 2019, 15:21 »
I've had my GTi PP 5.5 years, nearly 37K miles. Just had to have the water pump, thermostat etc all replaced. Cost £785 at a local non-VW garage. Apparently it's a right nightmare to do. I'd keep a close eye on your temperature, and if it starts creeping higher than normal, get it into a garage swiftly.
2014 GTi Mk7 5dr Manual, Reflex Silver, PP, DNS, Dynaudio, Pano Roof.
Offline Rob_benton
« Reply #3 on: 12 August 2019, 17:39 »
Or take out a private  warranty now and the water pump will more than cover the cost !
2014 gti pp dsg
Offline Finglonga
« Reply #4 on: 13 August 2019, 17:16 »
Did you top up the coolant when the engine was cold. The fix is not that expensive if it is the water pump if you use a specialist independent, it is expensive if you use a main stealer.
