Author Topic: ACC?  (Read 5413 times)
Offline king monkey
ACC?
« on: 07 August 2019, 16:32 »
Hi guys,
Came out of a Vw dealers today as I was having a sneaky look at a TCR and the ACC came on, slamming to to a sudden stop. Thought I’d hit something as there was a slight slope leading out of the dealers. Very very slight though. Any ideas why this might happen and was it ACC related?
Offline itavaltalainen
Re: ACC?
« Reply #1 on: 07 August 2019, 16:36 »
Front assist (not ACC!) must have thought you'd crash into something.
Offline sjw
Re: ACC?
« Reply #2 on: 07 August 2019, 16:38 »
Hi guys,
Might have been the front assist/emergency maneuver braking/ whatever it is called. It's very alarming when it happens. Can be turned off, but think you have to do it each time you're going slowly enough to park?
Offline king monkey
Re: ACC?
« Reply #3 on: 07 August 2019, 16:40 »
Sorry, that’s what I meant! Oops. Thought I had tbh.
I was using ACC the a few months ago and the car didn’t slow when approaching traffic. Never had this in my Pp gti so came as a bit of a surprise to say the least.
Offline Yusee
Re: ACC?
« Reply #4 on: 07 August 2019, 16:44 »
It’s the slope. Sensors will have detected the ground.
Same happened to me yesterday reversing onto a steep driveway.
Gives you quite a shock- I thought i’d hit something!
You can turn off manoeuvre braking via the parking menu, and front assist through the driver assistance menus.
Offline king monkey
Re: ACC?
« Reply #5 on: 07 August 2019, 16:47 »
Thanks for the replies. I checked and double checked as I really thought I’d hit something. Think I’m going to look at turning this off.
They didn’t have the tcr in either. 😂
Offline Yusee
Re: ACC?
« Reply #6 on: 07 August 2019, 16:50 »
Hi guys,
A very very slight slope? That does seem unusual. Perhaps you accelerated quickly??
Offline fredgroves
Re: ACC?
« Reply #7 on: 07 August 2019, 16:50 »
Maneuver braking... it comes on if its in park mode... did you reverse out of the parking space by any chance?
Park mode doesn't come off until either you press the button or exceed something like 15mph.
Up until then, if the ultrasonic parking sensor spot something and it thinks you're gonna hit it.... crunch on come the brakes.
It can and does spot the road surface when you come down steep slopes... like my friend's driveway...
You can disable braking in the menus if you want... I'd recommend that you don't.
Offline sjw
Re: ACC?
« Reply #8 on: 07 August 2019, 16:51 »
When the parking sensor display is up, there'll be two buttons. One turns off the audible warning, the other toggles off the manoeuvre braking (for that park only)
Offline sjw
Re: ACC?
« Reply #9 on: 07 August 2019, 16:51 »
Also, I may be mistaken, but I think if you disable it in the menus, it is only until you turn the car off? Maybe I'm wrong
