Golf mk2
Fuel pump
Topic: Fuel pump (Read 12247 times)
Rickymk2
Just got here
Fuel pump
13 July 2019, 11:41 »
Hi hoping someone can help me I have a mk2 1.3
That I plan to swap to an 8v I’m going to use mk3 tank
And pump ect am I able to just use the mk3 pump
Wiring from the pump to fuse box will this just be all plug and play
Or do I need to change any of the wires over ect
It’s a ce2 car I’m fitting it to
vr6 south
Re: Fuel pump
20 July 2019, 18:26 »
Check the pressure rating of each pump. If they are the same you shouldn’t have any issues. They are probably 3 bar.
Simeon
Re: Fuel pump
22 July 2019, 17:45 »
MK3 tank and wiring loom, will plug straight into your fusebox, job done. Only engine the MK3 GTi / VR6 tank won't run is the KR 16v.
Golf mk2
Fuel pump
