Golf mk2
gti washers
Topic: gti washers (Read 2015 times)
pal1
gti washers
27 October 2003, 16:45 »
does anyone have a decent wiring diagram of the washers on a mk2 gti mines playing up
Blue MK2
Guest
Re:gti washers
27 October 2003, 17:57 »
Whats the problem with the washers?
pal1
Re:gti washers
28 October 2003, 10:09 »
rears dont wash or wipe fronts only wipe but dont wash have tried a new washer pump and that will only work if you swap the pipes over so you push the stalk to wash the front then wipe with the normal wipers the stalk is ok because i'm getting a voltage feed at the pump end when its pushed or pulled i just cant get it working together
Blue MK2
Guest
Re:gti washers
28 October 2003, 10:47 »
Disconnect the washer hoses at the ends and see if water pumps through??
Might be cloged up washers?
Also the rear wiper motor might be seized.
Last Edit: 28 October 2003, 10:48 by Blue MK2
golfvr6
Guest
Re:gti washers
28 October 2003, 11:00 »
The washer jets easily get clogged up, so disconnecting the hoses sounds like a good idea. On both my last 2 cars, i have had to replace the rear jet as it was so clogged, only a couple of quid from vw.
Golf mk2
gti washers
