Author Topic: Is manual mode different if you enter it from Drive or Sport?  (Read 2764 times)
Offline sjw
The guys over at VWROC reckon it does, but I'm not sure. I'm in a GTI
Offline kmpowell
It's supposed to be different, but like you I'm not so sure. My reason being...
If I set my car to 'sport' mode and the gearbox is showing 'S', sitting with the engine at idle I can switch the lever/paddle to 'M' gears and the idle revs will drop, indicating it's not so eager and under a different RPM setting to Sport.
So I'm not convinced that Manual mode isn't just one setting, rather than being manual gears for each mode you may be in.
:huh:
SOLD March 2021
Offline Jim_mk7.5
Good question. I've wondered that but when S is engaged stationary and you flick over to M, the revs drop back the same as they do by going back to D. Sometimes have found myself engaging S before going to M but couldn't say if it's because it feels or is different.
NOW - 330e M Sport
Offline Jim_mk7.5
:huh:
You beat me to it!
NOW - 330e M Sport
Offline sjw
Yup, I don't think there's a difference. The VWROC guys reckon that it is louder (valves open, which we don't have) and the gears change faster (why would there be a slow option?)
I have unplugged my soundaktor, so I can't test if that is any different, but I would be inclined to believe that that is the only way manual could be any different between the 2 modes
Offline Jim_mk7.5
I have the res delete and some nights I leave work and it sounds louder than others, especially in S. But then it does make a really good noise in Eco as well but I don't often use it  :grin:
NOW - 330e M Sport
