Author Topic: MK3 or MK4 calipers  (Read 2194 times)
Blue MK2
MK3 or MK4 calipers
« on: 27 October 2003, 16:30 »
When i brought my J reg MK2 the guy got a new rear left capliper by VAG.
I went and brought a rear right one to match but it dont seem to fit. The hoses are on the wrong side.
Could the fitted caliper be one from a MK3 or MK4 with a few mods?
Any ideas?
« Last Edit: 27 October 2003, 17:50 by Blue MK2 »
golfvr6
Re:MK3 or MK4 calipers
« Reply #1 on: 28 October 2003, 00:04 »
The mk3 ones will fit straight on the late mk2s, not sure about the mk4 ones. Are you sure they haven't given you another left hand one?
golfvr6
« Reply #2 on: 28 October 2003, 00:05 »
The mk3 rear calipers are much better than the mk2 ones as the handbrake mechanism is internal, this is what always seizes up on the mk2 model.
Offline Gambit
« Reply #3 on: 28 October 2003, 09:08 »
the mk4 calipers are the same as the mk3 calipers except they are alloy
as VR6 said, the handbrake mechanism's are internal, so if you can see the spring & rachet on yours then its a mk2
i would suspect he's givin you another left hand caliper also
Blue MK2
« Reply #4 on: 29 October 2003, 12:47 »
I got the caliper from Lucas so it must have been the write one. I also got a right hand caliper off a scrap car with the same reg. Still didnt look write?
Any ideas?
Offline Gambit
« Reply #5 on: 29 October 2003, 13:04 »
the difference between early & late mk2 calipers is that that handbrake mechanism is on the side of the early calipers, this was then moved to the back of the late calipers
