Author Topic: special tool required for crankshaft pulley removal ????????  (Read 1498 times)
Offline gti newbie
Hi, first post on the forum, although we have been rather regular visitors of late as have brought our first Golf, a mk11 8v ('85) :cool:
We are in need of help as we want to remove the timing belt as it is one tooth out and affecting the engine timing. The trouble is we can't seem to shift the retaing bolts on the pulleys.
Is there any tool or a certain way in which you have to hold the crankshaft pulley / water pump pulley in order to remove the relevent pulleys. We have tried to remove these but the pulleys just turn (obviously) as the retaining bolt is rather stiff.
Any help would be most gratefull,
Ta!
Offline ...joe
Re: special tool required for crankshaft pulley removal ????????
« Reply #1 on: 12 October 2005, 19:12 »
i've never had a problem un-doing the bolts but i'd soak the hell out of them with wd40 for as long as possible, then if you can clamp the pulley with something thats not going to damage it try to hold it in place while you undo the allen heads. i doubt it'll be easy but i guess its the only way.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline gti newbie
« Reply #2 on: 12 October 2005, 21:38 »
Thats the thing trying to find something suitable to hold the pulleys and with out wanting to damage them. We shall give them a good soak for sure  :smiley: Although these buggers seem to be welded on  :laugh:
« Last Edit: 12 October 2005, 21:40 by gti newbie »
Offline ...joe
« Reply #3 on: 12 October 2005, 23:29 »
if all else fails get a bit of heat on there, amazing what warming things up can do!
Offline AudiA8Quattro
« Reply #4 on: 13 October 2005, 00:19 »
For the crankshaft pulley, use a socket or 19mm spanner on the centre nut to hold it still.
For the water pump pulley use a set of stilsons on 2 of the allen key bolts while undoing the others, then switch the stilson onto the other 2.
For the power steering pump pulley, an allen key fits into the centre to hold it still.
Amazing what you remember when you have done the job yourself  :laugh:
Offline richandhazel
« Reply #5 on: 13 October 2005, 00:48 »
Oh Corin, you can't resist it can you..............just remember, you're not the only one :wink:
Try doing different marques..........they can really be a PITA :shocked:
« Reply #6 on: 13 October 2005, 20:01 »
 :laugh:
Offline gti newbie
« Reply #7 on: 15 October 2005, 19:20 »
Cheers for the help, the suggestions for holding the pulleys worked a treat  :smiley:
