Author Topic: Mk6 GTD map/thrust sensor.  (Read 2461 times)
Offline Chele
« on: 27 May 2019, 14:50 »
Hi Guys.
 I have one  fault code in vcds as follows.I have no warning lights on dash but very very occasionally I will get the glow plug light on at start on/off clears it.
Fault code below I have looked bloody everywhere Iv resorted to bumber removed for a better view. Iv looked on all pipes including the plastic charge air pipe I just cant see it anywhere. Fault below. Engine code is (cbb)?
1 Fault Found:
005522 - Altitude Sensor / Boost Pressure Sensor
               P1592 - 000 - Implausible Correlation - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 31
                    Reset counter: 255
                    Mileage: 134032 km
                    Time Indication: 0
                    Date: 2013.10.05
                    Time: 13:12:20
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.01 V
                    Absolute Pres.: 999.6 mbar
                    Absolute Pres.: 1162.8 mbar
                    Temperature: 11.7°C
                    (no units): 1.0
Any help appreciated in this because I'm at a lost end, two days spent looking for it to no avail  its getting me  :angry:
Offline jv
  • Administrator
Re: Mk6 GTD map/thrust sensor.
« Reply #1 on: 28 May 2019, 08:02 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
