Author Topic: Nav Pro & Rear Camera  (Read 2414 times)
Offline CookieMonsterGTi
« on: 27 April 2019, 20:24 »
Just wondered if anyone could point me towards the difference between the standard nav and the pro system apart from the larger screen and gesture controls?  Is it functionally the same? Is the screen resolution/quality the same? Is it worth it?
With the rear camera do you get guide marks as you turn the wheel or is that an option which is part of a parking package?
Thanks.
Pure Grey GTI TCR 5 Door DSG
19" 'Reifnitz' Alloys Including DCC
Climate Windscreen
Panoramic Sunroof
90% Rear Tinted Glass
Offline Vwjap
Re: Nav Pro & Rear Camera
« Reply #1 on: 27 April 2019, 20:31 »
There’s 2 cameras highline and lowline, highline comes with bendy lines, lowline doesn’t, mine has got trailer assist so has the highline in it (but I’ve programmed it to lowline because it works better)
As for the difference between the nav’s the pro has a hard drive so you don’t loose a sd card space, and you can load your somgs on your hard drive, also if you get the AID clocks the pro will show the map on both screens at the same time, whereas the lower model it’s either on one or the other, I’m sure there’s more but I’ve not seen the standard nav
Offline Guzzle
« Reply #2 on: 27 April 2019, 21:19 »
7.5 GTD
« Reply #3 on: 27 April 2019, 21:26 »
How is lowline better? Would have expected from the name high line would be the better if the two?
Climate Windscreen
Panoramic Sunroof
« Reply #4 on: 27 April 2019, 21:27 »
Climate Windscreen
Panoramic Sunroof
Offline Vwjap
« Reply #5 on: 27 April 2019, 22:43 »
the highline doesn’t switch off till about 10mph or you put it in drive so you loose park pilot in going forward, ok you get lots of new camera angles with the highline but TBH I’ve never really used them after the thrill wore off, whereas the lowline as soon as you take it out of reverse it switches from camera to park pilot which I find much better
