Author Topic: Spacesaver pressure  (Read 6332 times)
Offline Yusee
Spacesaver pressure
« on: 06 April 2019, 16:30 »
Checked the pressure on my spacesaver for the first time today ( i’ve had the car 3 months) and noted that it was deflated. I filled it to the stated 60 psi and put it back.
Question is- are spare wheels checked and inflated to the required pressure at pdi, or are they kept under inflated for some reason ( save weight?).
My only other thought is there may be a slow leak. Any thoughts appreciated.
Offline Watts
Re: Spacesaver pressure
« Reply #1 on: 06 April 2019, 17:04 »
Not too sure some extra air will make any difference to the weight... :whistle:
Just keep an eye on it and see if it goes down.
Previously:
Offline dubber36
« Reply #2 on: 06 April 2019, 17:27 »
They should be checked at PDI. Whilst it's not a requirement to carry a spare, if you do, it's an MOT failure if it's flat or bald or damaged.
Offline Yusee
« Reply #3 on: 06 April 2019, 18:02 »
Haha, yeah- on reflection the weight suggestion probably a bit dim- it certainly felt heavier when I put it back, I thought there may be some perverse industry incentive to keep kerb weight down a fraction!
Most likely a sloppy pdi but i’ check again in 2 weeks
Thanks both.
Offline Watts
« Reply #4 on: 06 April 2019, 18:25 »
Thanks both.
 :smiley:
Previously:
Offline Lump
« Reply #5 on: 07 April 2019, 13:54 »
60 psi? Sounds a lot.
steve12345
« Reply #6 on: 07 April 2019, 14:32 »
I think I need to check my tyres and spare tyre pressure too after reading this.
The sticker inside my filler cap/flap is pretty much non exsistant, not sure how that would come away?!?
What pressure is recommend for mk7 Gti’s (non performance pack)? On the 4 fitted wheels and the spare? I’m running standard 18 wheels.
Thanks
Offline Talk-torque
« Reply #7 on: 07 April 2019, 14:34 »
It’s actually moulded into the tyre wall. Narrow tyre = high bearing load.
Roger.
Offline Yusee
« Reply #8 on: 07 April 2019, 14:54 »
Thanks
Recommended pressure is 38- though you will see discussion on here that 38 is too high- and 60 for the space saver. I’ve been checking pressures and oil regularly but hadn’t bothered checking the spare until now - definitely worth doing
Offline Talk-torque
« Reply #9 on: 07 April 2019, 14:57 »
Thanks
Recommended pressure for 18” tyres on the Mk7 non PP was 36psi. I used to run mine at 34psi, with no ill effects.
Roger.
