Author Topic: VCDS Need Help To Understand The Problem  (Read 3104 times)
Offline Matas
« on: 01 April 2019, 20:18 »
Hello guys, I'm new here, got dyagnostics done today and I got a few problems, can you explain what may be wrong with these?
The car is Seat Ibiza 2.0 16v ABF engine.
Address 01: Engine        Labels: Redir Fail!
   Part No: 037 906 024 BE
   Component: DIGIFANT 3.2        2121
   VCID: 56A45D1AB29C1DF1E3-0962
2 Faults Found:
00740 - Cylinder 1 Recognition Sensor (G145)
            03-00 - No Signal
00523 - Intake Air Temp Sensor (G42)
            30-00 - Open or Short to Plus
Readiness: N/A
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 H
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 16416
   Shop #: WSC 11111
   VCID: 3664FD9A12DC3DF103-4B00
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
            35-00 -  -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            35-00 -  -
            16-10 - Signal Outside Specifications - Intermittent
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 603 AC
   Component: AIRBAG VW3 -        V04
   Coding: 16707
   Shop #: WSC 06406
   VCID: 6ADC19EA16E4A91157-4B00
No fault code found.
Address 25: Immobilizer        Labels: 6H0-953-257.lbl
   Part No: 6H0 953 257 A
   Component: IMMO VWZ3Z0W8232295 V68
   Coding: 09600
   Shop #: WSC 00000
   VCID: 2E54D5FAEA8C05314B-4B4A
1 Fault Found:
01176 - Key
            65-10 - Unauthorized - Intermittent
