Author Topic: Seats  (Read 1070 times)
Offline Haribo!
Seats
« on: 11 October 2005, 18:03 »
ive got 2 golfs one is a 5 door the other is a 3 door, my 3 door has the grey seats with a few colored lines on it and my 5 door has these really nice half leather dark green and black seats , basically i want the black ones in my 3 door, but obviously the front seats wont move forward to allow others accsess to my rear seats, anyone got any ideas?
Re: Seats
« Reply #1 on: 11 October 2005, 18:51 »
The tilt mechanism is fitted to all MK2 seats, you just need to cut a slit in the right place on the side & fit the handle & surround.  Double check by looking at the base, you should see the 2 hooks that need to lift up in order for the seat to flip forward :)
Offline ...joe
Re: Seats
« Reply #2 on: 11 October 2005, 18:57 »
^^ what he says or use it as an excuse to not have to take people in the back!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Haribo!
Re: Seats
« Reply #3 on: 11 October 2005, 18:58 »
cheers lads,
Offline Mr Blue
Re: Seats
« Reply #4 on: 11 October 2005, 19:02 »
i have this problem.
I just move the mechanism forward by hand. missions though  :angry:
Offline Haribo!
Re: Seats
« Reply #5 on: 12 October 2005, 00:10 »
ive just done it, i had to saw away this bit of metal tho, i think the idea was to undo the screw driver hole thingy but i couldnt undo the bastard, so now the seats not as stable as i think it needs to be to pass an MOT, cause i only have one clip thing, ill have to keep the old seats so i can put  them on for MOT time :D
Offline 1 Lp
Re: Seats
« Reply #6 on: 12 October 2005, 17:00 »
If u dont mind abit of hard graff, swap the to backs around.
1. remove the seat covers ( roll the seats as far foward as they can go, then u'll c sum metal clip, type tings cut them with a side cutters then remove covers).
2.at the bottom edge on either side u'll c sum bolts undo them (cnt member the size 17mm I think??) then the seat will cum apart
3. swap em over then follow steps one and 1&2 again ( the clips that hold the covers on are called hog ring, u need to buy sum, and a hog ring tool to put them on).
hope this helps, I a trimmer so I know this works 4 a fact.
VWs are like women, they need love care and attention
