Author Topic: GTI Performance brakes retrofit?  (Read 8291 times)
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« on: 25 November 2018, 10:13 »
Has anyone done it and/or have any info?
Thanks
Re: GTI Performance brakes retrofit?
« Reply #1 on: 25 November 2018, 16:36 »
Easy retrofit.
But not cheap if you use all new parts. P
Offline Golf_GT_TDI
« Reply #2 on: 25 November 2018, 20:43 »
Thanks, calipers, discs and backplates all round? Or are front calipers the same?
« Reply #3 on: 26 November 2018, 01:37 »
The front calipers are much bigger.
There are probably part numbers listed on forums if you search.
The PP GTI  brakes are the same as the Clubsport (non S) and the R (albeit differently painted calipers) and the Leon Cupra.
Somewhere out there someone will have done a retrofit.
Offline fredgroves
« Reply #4 on: 26 November 2018, 12:41 »
If you are going to fit non-OEM brakes (and I mean not OEM for your GTD) then why not fit some proper top of the line third party ones?
Probably no more expensive (VW parts expensive!), same issue with insurance and resale...
Might as well get the best stoppers out there...I would.
Offline Golf_GT_TDI
« Reply #5 on: 26 November 2018, 21:05 »
Thanks, if I go ahead (it's actually for another car) I would need to source used set of calipers/carriers. I managed to dig out some part numbers from ETKA so will post those in case anyone else needs them...
Front
Caliper, red, left - 5G0 615 123 A
Caliper, red, right - 5G0 615 124 A
Carrier, red, left - 5G0 615 125 A
Carrier, red, right - 5G0 615 126 A
Pads - 8V0 698 151 C
Discs, 340x30mm - 1K0 615 301 AD
Backplate, left - 5Q0 615 311 F
Backplate, right - 5Q0 615 312 F
Rear
Caliper, red, left - 5Q0 615 423
Caliper, right - 5Q0 615 424
Carrier, red - 5Q0 615 425
Pads - 3Q0 698 451
Retaining spring - 8V0 615 269
Discs, 310x22mm - 1K0 615 601 N
Backplate, left - 5Q0 615 611 N
Backplate, right - 5Q0 615 612 N
Offline fredgroves
« Reply #6 on: 27 November 2018, 09:53 »
Go on, what's the price for that lot then...
Offline Jim_mk7.5
« Reply #7 on: 27 November 2018, 10:15 »
Bet with would be cheaper to get a big brake big as you suggested from somewhere like Awesome GTI -https://www.awesomegti.com/shop-by-brand/racingline-performance/racingline-performance-monoblock-brake-kit-345mm/
All this chat is pretty irrelevant really as Op hasn't said what car its for and what it will be used for  :undecided:
NOW - 330e M Sport
Offline hobbes22
« Reply #8 on: 27 November 2018, 12:20 »
I don't know how that much that lot will cost from VW, but suddenly the extra £1000 for the Performance pack with the brakes and LSD suddenly seems a pretty good deal!  :grin:
Sold - Octavia 2.0 PD Tdi. Shark remap. EGR Delete. Decat. H&R Shocks. Hybrid Turbo.
Sold - 2016 GTI PP, Manual. Pure White. Keyless.
Current - GTI Performance, DSG, Isaac Blue, Brescia 19”.
Offline BobbyT
« Reply #9 on: 27 November 2018, 12:48 »
There must be loads of R brakes for sale around Brum and Manchester. Get on Ebay and buy some red paint  :undecided:  :tongue:
