Author Topic: Warning Lights  (Read 3154 times)
Offline Tornado8
Warning Lights
« on: 14 October 2018, 13:16 »
Firstly the Acc error came up and de-activated, then the start-stop showed an error, then the EPC light came on, then the cat light came on  :rolleyes: It is difficult to start the car but once running, runs fine i.e not in limp mode. Any ideas. Thanks in advance.
Old, but a serial modder!
Offline Mikeyd1
Re: Warning Lights
« Reply #1 on: 14 October 2018, 18:21 »
Possibly battery.i know when they get low it can cause all sorts of warning lights. Check your battery is the first thing u should do
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Offline hobbes22
Re: Warning Lights
« Reply #2 on: 15 October 2018, 13:15 »
It does sound like it could be a single fault is causing this, as Mikey says, the battery is a good place to start, check the connections. I had a negative battery terminal lead which wasn't fully tightened on my last car which gave all sorts of issues. Either this or your car is having a catastrophic episode!  :wink:
Sold - Octavia 2.0 PD Tdi. Shark remap. EGR Delete. Decat. H&R Shocks. Hybrid Turbo.
Sold - 2016 GTI PP, Manual. Pure White. Keyless.
Current - GTI Performance, DSG, Isaac Blue, Brescia 19”.
Offline Finglonga
Re: Warning Lights
« Reply #3 on: 15 October 2018, 16:12 »
Classic symptoms of a battery on the way out as I had similar warning lights first start of the day. Then one day it simply did not crank over as the battery had died.
Offline Tornado8
Re: Warning Lights
« Reply #4 on: 15 October 2018, 20:32 »
Thanks for that, I will check the connections tomorrow.
Offline ianmk4
Re: Warning Lights
« Reply #5 on: 28 October 2018, 08:14 »
Did you get this fixed?
I had the exact same errors in the same order too. I call out breakdown and they hooked it up to diagnostic machine. Turns out I need a new water pump and thermostat housing as there was a leak. Check your coolant level.
Offline Tornado8
Re: Warning Lights
« Reply #6 on: 29 October 2018, 19:29 »
Well took it in, firstly the camshaft actuators on one bank were replaced, then found no spark to one bank(only 3v) from coil pack, found water ingress in harness side of relay in connector, then  water in coolant shut off valve so wiring repair and new plug. Now running better than ever :laugh: but  a b****y nightmare. :cry:
