Golf mk7
Jimble
19” Brescia Tyre Pressures
Topic: 19” Brescia Tyre Pressures (Read 10741 times)
Beezer
28 September 2018, 23:27 »
Anyone know the correct tyre pressures for the above?
Had a pressure loss warning pop up, but the tyre feels solid enough so don’t think it’s a puncture.
The sticker on my drivers door frame seems to refer to R18s.
Watts
Forum addict
Re: 19” Brescia Tyre Pressures
29 September 2018, 11:42 »
Seems strange your's doesn't have 19s pressure data, you'd have thought the sticker would be standard? Anyway, 2.8 (41) all round except for heavy loads then 3.0 (44) front and 3.3 (48) rear.
Previously:
mcmaddy
Forum addict
29 September 2018, 12:17 »
Didn't VW up the pressures on the FL? 41 seems really high when Mk7 gtis are 36 all round.
Watts
Forum addict
29 September 2018, 12:24 »
Quote from: mcmaddy on 29 September 2018, 12:17
Mine's a MK7, 36 all round is for 18s rather than 19s. Not sure about any changes for the facelift.
Previously:
mcmaddy
Forum addict
29 September 2018, 12:57 »
I'm sure it was 36 all round for 19s when the Mk7 came out.
Beezer
29 September 2018, 13:35 »
Thanks for the help guys. Double checked my sticker and it’s definitely different to the one above.
On the left there’s no mention of tyre size. There’s the two options for loading and it shows 41 psi for standard use so that must be generic regardless of wheel size.
In the larger text at the bottom there’s a reference to R18 that was confusing me.
Anyway I’ll top them up to 41 and see how it goes.
jaceyboy
Reply #6 on:
29 September 2018, 13:45 »
Would be interested in this for our 19" Prets
MK7 GTi
davyk31
Reply #7 on:
29 September 2018, 19:31 »
The text at the bottom only refers to the spare tyre does it not?
Mk 7.5 GTi Indium Grey with 19" Brescias
C2K
Here all the time
Northern Monkey
Reply #8 on:
01 October 2018, 10:42 »
That's definitely gone up - presumably the Mk 7.5.
My '14 GTD said for 225/35/19s:
39 psi F+R for normal load
42F 46R for heavy loads.
Gone up 2 psi all around, wonder why as mine's fine.
The bottom text is for the spacesaver yes.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
MKgti
GTI forum regular
Reply #9 on:
01 October 2018, 10:59 »
Mine says 41psi all round. I think 44 if loaded.
I run them at 38 front 39 rear as I find it to harsh at 41.
Collected and being driven....... Gti PP 5dr DSG Tornado red, tints and Brescia's.
Golf mk7
Jimble
