Author Topic: Recent dealer visit  (Read 4170 times)
Offline vw spur
Recent dealer visit
« on: 18 September 2018, 10:54 »
Had my GTD in at the dealers last week, had a couple of little niggles which I’d been meaning to get sorted but then a 3rd one appeared which made me get the car looked at.
1st one was the headlight washer jets were staying stuck out & not sliding back into the bumper after use, had to gently push them back in by hand. The fix to this was a bumper off job & replace the washer jets on both sides, apparently there’s a bulletin on these & a known fault.
2nd one was a key fob that I had replaced, original had the GTD logo on the fob but the replacement was a standard fob a little bit smaller than the original GTD logo one. When I queried why the key was different I was told only GTD fobs were issued with a new car & any replacements wouldn’t be the same as the originals. I find that a bit hard to believe, I DM’d VW HELP on Twitter & they weren’t interested & pushed me back to the dealer if I wanted to take it further, I only wanted them to tell me if a replacement GTD key fob could have been supplied as a replacement. I haven’t bothered to try again since. Just unsure of how any future buyer would feel about 2 different fobs.
3rd this was what sounded like a wheel bearing had gone but turns out it’s not that, it’s the rear tyres wearing on the inside which is causing excessive road noise, it’s very loud. Been told the fix is 2 new rear tyres & a 4 wheel alignment done to rectify the cause. Bit annoyed as my rear tyres are the originals & have 5mm left.
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline Carbon VW
Re: Recent dealer visit
« Reply #1 on: 18 September 2018, 13:45 »
AFAIK the chrome logo part of the key is an accessory that is just fitted into a normal key. Be it an R, GTI OR GTD. My car is 5 years old,never had wheel alignment done since the factory and I get 40,000km from a full set of tyres which I rotate.
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline kalimon
  • My other car's a van
5 DR Mk 7 GTI PP
Offline mcmaddy
« Reply #4 on: 18 September 2018, 15:06 »
If the garage have replaced your genuine key then they should replace it like for like. Maybe ask them to remove the gtd bit from the bottom of your old key. They sound a bit slap dash if you ask me  :whistle:
Offline Guzzle
« Reply #5 on: 18 September 2018, 19:23 »
The key fob issue sounds like nonsense to me. You've paid for a GTD, so should get the same GTD fob as a replacement. If the wheels had whiteworm, would they expect you to accept SE wheels as replacements?  :sad:
7.5 GTD
Offline fredgroves
« Reply #6 on: 19 September 2018, 07:40 »
How many miles have you done?
My last GTD did exactly the same - think it was at about 60k
Don't bother with wheel alignment, just stick two new tyres on the rear. Its not an alignment fault, its just the way the rear end works on a Golf.
Offline dubber36
« Reply #7 on: 19 September 2018, 11:10 »
Get the alignment done. The car will feel like it should again. I was amazed how my Mk6 was transformed after suffering the same.
Offline joe6
« Reply #8 on: 20 September 2018, 19:36 »
Make sure you get the check done using the Hunter alignment equipment or similar to get a good realignment. This problem with rear wheels is a VW issue on some vehicles across a number of models. Had it on my Scirocco.
