Author Topic: Is Auto Stop Start Worthwhile?  (Read 7662 times)
Offline wantmygti
Re: Is Auto Stop Start Worthwhile?
« Reply #10 on: 08 September 2018, 11:19 »
was also under the impression that hot engines (specifically turbos) don’t like being turned off when hot repeatedly. Maybe a myth, not sure...
Yes of course, VW would fit something which would dramatically increase the chances of warranty claims for broken turbos, because that's such a cheap and easy thing to fix that its perfectly offsetting the environmental benefit...
A warranty is only 3 years long.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
« Reply #11 on: 08 September 2018, 12:01 »
Being as every newish car I’ve been in over the last four or five years has had stop start and most have been turbo cars I think the cooling of turbos has been engineered well enough now for it to not reflect reliability.
If anything it’s the batteries that get the hardest time. I have had to have one replaced myself in my GTI PP.
The turbos don’t need warming up or down like in the early days and last a lot longer.
I’m of the opinion that Stop Start is great in manual cars and probably a headache in DSG equipped models.
I think we are stuck with it whatever for a few years until combustion engines slip away into the history books.
Offline Vwjap
« Reply #12 on: 08 September 2018, 14:30 »
Unless you have auto hold on
Offline trueblue_ips
« Reply #13 on: 08 September 2018, 14:35 »
The worst thing fitted to modern cars imho.
Why do we consumers put up with it?
It should be an option that you can choose or not.
It's just unnatural for me for a car to be constantly shutting down and starting up again and must place unnecessary stress on parts of the car.
Offline SRGTD
« Reply #14 on: 08 September 2018, 15:41 »
But you can choose; you have the option of switching it off. It’s become part of my starting procedure to switch off stop start when I start my engine. I usually only re-activate stop start if I know I’m going to be sitting in stationary traffic for any length of time.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline dervdave
2016 GTD
Offline monkeyhanger
« Reply #16 on: 08 September 2018, 15:52 »
With DSG, letting go of the brake causes the car to restart again after a stop.
Not on my 7.5 PP dsg it doesn't, it's only when you touch the throttle or the car in front moves. That's one of the things I like about it compared to earlier versions - you don't have to dazzle the drivers behind with your brake lights on.
Throttle blip rather than brake release is probably tied in with the function of the autohold - Polo has old school handbrake which I only put on when parking the car up. The Polo always wants to creep forward when not restrained by the brakes, which is fine with me, but firing itself back up because the car in front has shuffled forward and I have not triggered the restart is by far my biggest annoyance.
« Reply #17 on: 08 September 2018, 15:56 »
I coded it out straight away.
If you could disclose the coding pathways via VCDS or OBD11, i'd be most grateful!
Offline Booth11
« Reply #18 on: 08 September 2018, 16:39 »
Stop start on DSG is a real hinderence ime. Best coded out completely.
Obdeleven coding - Disable stop/start
Select Control unit 19
Adaptation
Stop start limit voltage
Set Value to 12
(default is 7.6)
« Last Edit: 08 September 2018, 16:50 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline wantmygti
« Reply #19 on: 08 September 2018, 17:47 »
Adaptation
Set Value to 12
(default is 7.6)
That’s the one!
