Author Topic: Mark 7 GTI tyre size  (Read 5081 times)
Offline Peter Mitchell
« on: 22 August 2018, 19:23 »
I have a 2016 GTI with 19" optional wheels and 225/35R19 tyres. These give a rather harsh ride. Is it possible to fit higher profile tyres, say 225/40 or even 45 with these wheels  to soften the ride. Is there enough clearance in the suspension area for the  higher profile on these wheels or would I be forced to go to a smaller wheel/. Interestingly VW UK seemed unable/unwilling to answer this question!  Peter M
Offline Watts
Re: Mark 7 GTI tyre size
« Reply #1 on: 22 August 2018, 19:33 »
I suppose it depends on your frame of reference but I find my 19s to be pretty good, not perfect, but great most of the time. Have you checked the tyre pressures are correct? If you want to go for a lower profile though then you need to look at 18s. Might be worth trying a car on 18s first though before you commit! :smiley:
Previously:
Offline jv
  • Administrator
« Reply #2 on: 22 August 2018, 19:46 »
225/35 to 225/40's you aren't going to feel that difference. The speedo will be out by a mile or two but that's about it. Go to 45's and your speedo/mileage will be reading under by a fair bit.
Like Watts says, see if you can try a car on 18's - dealer test drive maybe?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline SRGTD
« Reply #3 on: 22 August 2018, 19:55 »
Bear in mind that changing to tyre with a different aspect ratio will result in a speedo error;
Compared to your current 225/35 tyres;
    With 225/40 tyres, your speedo will under-read by approx 3.4%. So at 60 mph true speed, your speedo will be showing just under 58 mph, and when your speedo is showing 60 mph, your actual speed will be just over 62 mph.
    Similarly, with 225/45 tyres, the speedo error will be under-reading by approx 6.6%. So at a true 60 mph, speedo will be showing will be 56 mph and when your speedo is showing 60 mph, your actual speed will be just over 64.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Gnasher
  • Formerly GnasherVXR
« Reply #4 on: 23 August 2018, 12:23 »
Don't know if there's space to fit larger tyres, but before you start panicking about speedo error, it's probably worth getting a GPS speedo set up so you can see how far the current speedo over-reads. Could be anywhere between 0 and 5%.
Also, there's a good chance it will rub the inside edge of the tyre on the arch liner at the front on full lock. Not sure about anywhere else though.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline Guzzle
« Reply #5 on: 23 August 2018, 12:40 »
You need smaller wheels or a different spring/damper set-up if the ride is causing you big trouble.
Changing tyre profile to 45 on same wheels doesn't seem a great idea to me. You find going from 225/35/19 to 235/35/19 helps a little as the tyre wall will be slightly deeper. Some members on Skoda forums reported a slightly more compliant ride on 19's by doing this, but may not make enough of a difference to you.
« Last Edit: 23 August 2018, 12:57 by Guzzle »
7.5 GTD
Offline Jim_mk7.5
« Reply #6 on: 23 August 2018, 12:57 »
Assuming you didn't try cars with both sizes before buying? Try and find someone who wants to upgrade to 19's and do a swap for their 18's. VW UK aren't going suggest running a different size tyre to standard. Imagine if you crash.
NOW - 330e M Sport
