Author Topic: Brake Problem  (Read 1802 times)
Offline 16vmk3ash
Brake Problem
« on: 10 October 2005, 01:15 »
Hi i have been having intermitent problems with my brakes since i had 3 new ABS sensors fitted about 10mth ago and i nead to sort it before my MOT runs out.
Some times when i press the brake pedal i get little movement in the pedal then it corrects itself and the pedal travels as normal. The feedback feel is kind of mechanical as if there is a pressure build up and there is also quite a loud noise (sort of grinding sound)!
Does anyone have any idea what the problem is? ABS pump, ABS ECU etc
Thanks
Offline AudiA8Quattro
Re: Brake Problem
« Reply #1 on: 11 October 2005, 00:10 »
Check the brake servo for leaks.
What happens if you pump the pedal when the car is stationary?(with the engine on)
Offline Len
Re: Brake Problem
« Reply #2 on: 11 October 2005, 13:39 »
Changing the ABS sensors would NOT have any effect on the performance or feel of the brakes in normal use. They only detect rotation of the wheel/driveshaft.
As 6 says and also try changing the brake fluid. Drain and flush it thoroughly, then refill with a good grade of new fluid.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: Brake Problem
« Reply #3 on: 11 October 2005, 13:40 »
Another thought - check that the calipers are moving freely.
www.sas.org.uk
www.the-ace.org.uk
Offline 16vmk3ash
Re: Brake Problem
« Reply #4 on: 11 October 2005, 21:27 »
If i pump the brake pedal with the engine on it acts as it would normally!, when this problem occurs though i have to pump the pedal a couple of times or keep my foot down for the problem to correct itself.
You say drain and flush the brake fluid throughly! would i do this the same way as a car without ABS or is there different procedures?
This noise i am hearing sounds like its coming from the handbrake area, which is where the brake lines for the rear run as well i think.
Offline Dom Mk3
  • Insert wit here
Re: Brake Problem
« Reply #5 on: 11 October 2005, 21:54 »
I had something similar when I had a leaking rear cylinder...
Offline Len
Re: Brake Problem
« Reply #6 on: 12 October 2005, 13:35 »
Then I think vr6 was right, sounds like a servo problem.
Havent done a Golf but changed the fluid on my 405 Mi16 and had no problems. Just watch that initial spurt of fluid - best to undo a bleed valve first. It is supposed to be recharged, but all I did was do a hard breaking until the ABS clicked in and had no probs since!
www.sas.org.uk
www.the-ace.org.uk
