Author Topic: Has anyone got the full brake lights to work using OBD11 on Mk7.5?  (Read 6511 times)
Offline JB GTI
As per the title. I am trying to get the inner brake lights to work on my Mk7.5. I did it no problem on my Mk7 have seen a few adaptions that are supposed to work for the Mk7.5 but none of them make any difference!!
Any help or instructions that definitely work would be most appreciated  :smiley:
Thanks in advance  :cool:
Now Gone: 3dr GTI Carbon Grey Performance Pack Dynaudio
Discover Nav Park Assist Rear Camera
Picked Up: 15th March 2014
Now Gone 3dr Golf R Lapiz Blue, DSG, Dynaudio, 19" Pretoria's, Discover Nav, Keyless, Rear View Camera
Picked Up: 1st March 2015
Now Gone Too: Mk7.5 Golf GTi Performance 5dr Indium Grey DSG Dynaudio 19” Brescia Alloys Vienna Leather Keyless Entry/Start Panoramic Roof 90% Tints Park Assist Rear View Camera Voice Activation Dynamic Lane Assist/DLA
Offline Vwjap
What rear lights you got? Mine are the none dynamic ones and do not have LED on one side and the one on the other side is a fog light
Offline JB GTI
Full led rears
Offline Booth11
Hi JB
I coded someone’s 7.5 R a couple weeks back and did the inner brake lights adaptation using obdeleven and it worked fine.
This was the coding used.
9- Central Electronics
16- 31347
10-Adaptations
Left side inner:
Change [8] Leuchte23sl HLC10 - Lichtfunktion C23 from Not Active to Brake Light
To increase brightness:  Change [10] Leuchte23sl hcl10 - Dimmwert CD 23 from 0 to 100
Right side inner:
Change [8] Leuchte24sl HRA65 - Lichtfunktion C24 from Not Active to Brake Light
To increase brightness: Change [10] Leuchte24sl HRA65 - Dimmwert CD 24 from 0 to 100
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline JB GTI
Hi JB
16- 31347
10-Adaptations
Left side inner:
Right side inner:
Yes. These are the instructions I tried. When I went into Central Electrics it didn’t ask for the security code as per the instructions until I had done the coding but says the adaptions were successful. Also, I am assuming that brake light is “Bremslicht” in the availability options??
Did you have to do any kind of light reset after to get them working?
Thanks  :smiley:
« Last Edit: 29 July 2018, 09:44 by JB GTI »
Offline Booth11
Hi JB
16- 31347
10-Adaptations
Left side inner:
Right side inner:
Yes. These are the instructions I tried. When I went into Central Electrics it didn’t ask for the security code until as per the instructions until I had done the coding but says the adaptions were successful. Also, I am assuming that brake light is “Bremslicht” in the availability options??
Thanks  :smiley:
I can’t exactly remember about the security code bit as I did a few different adaptations that day, but I tend to just troubleshoot things if they don’t follow the prescribed route!  It’s possible I might have gone into the security code menu and entered it there when there was no prompt for it earlier but can’t remember.
Yes Bremslicht is Brake Light.
No, there was no reset done, just the coding.
Others have said they’ve used the same coding as in a pre facelift and that’s worked. See coding below for that.  But I think you’ve tried this haven’t you?
Module 09 (Central Electrics)
Security Access 16
Code = 31347
Adaptation 10
Channel 8 -Leuchte27 NSL RC6
Lichtfunktion C27
Set to brake light = Bremslicht (default is not active)
Channel (10)-Leuchte27 NSL RC6
Dimming CD27
Set to 100 (default is 0)
 It’s confusing.
Hope you can get it sorted.
« Last Edit: 28 July 2018, 13:43 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline BristolBob
Could somebody please explain why anyone would need to modify a car's brake lights?
Golf GTI 7.5 PP DSG 2017
Offline Vwjap
so instead of just the outside lights coming on the inners come on as well so it’s easier to see your braking from behind with a full spread
Offline dubber36
It should also be noted that the full brake light option is for regions where rear fog lights are not required. In this country, a fog light has to be a minimum distance of 100mm away from a brake light. That's why we don't have the inner brake lights functioning.
Offline fredgroves
I was fairly sure there was a MOT construction reason rather than VW just being funny...
