Author Topic: Diamond cut alloy large stone chip  (Read 2718 times)
Offline Wrex22
« on: 27 June 2018, 23:02 »
I’ve just noticed a large stone chip on one of my Brescias  :sick: it’s on the black part. As the car is only 3 months in to a 24 month lease I don’t really want to get it refurbished yet. Any ideas on how to stop this causing any potential issues such as corrosion? I don’t really want to mention the curbing on the other wheel due to careless other half  :rolleyes:
Offline hog_hedge
Re: Diamond cut alloy large stone chip
« Reply #1 on: 27 June 2018, 23:08 »
I would give a clean using IPA and then use some touch up paint to ensure no alloy is exposed to the elements. There's not really much more you can do. From a distance my Brescia's look decent but close up they are peppered with chips :cry:
Offline Wrex22
« Reply #2 on: 27 June 2018, 23:11 »
Thanks   :sad:
Any idea of paint colour ?  I will get it repaired but with 2 more winters to get through I can’t see the point until I hand it back as because best as I try more chips are inevitable
Offline hog_hedge
« Reply #3 on: 27 June 2018, 23:19 »
I used L041. It's a VW flat black and it matches perfectly.
Offline Wrex22
« Reply #4 on: 27 June 2018, 23:24 »
Thank you . Just ordered some ! :smiley:
« Last Edit: 27 June 2018, 23:31 by Wrex22 »
Offline brettblade
« Reply #5 on: 28 June 2018, 10:56 »
+1 to what's already been said.  Fortunately it's on the painted part rather than the diamond cut part.  Once you've filled in the chip with paint, it'll be worthwhile using a hard wax or a sealant to protect the wheels from the elements too.  At the cheaper end of the scale, the Autoglym Alloy Wheel Protector will do the job, and at the other end there are ceramic sealants such as Gtechniq C5 and CarPro DLUX.
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline Gnasher
  • Formerly GnasherVXR
« Reply #6 on: 28 June 2018, 18:52 »
As an aside, if you get a chip on the clear part, you can do exactly the same with clear lacquer. I also found that if you get some G3 cutting compound on it after it's dried for a few days (IE before it's fully cured) you can get it down to looking almost as good as prior to the chip as the semi cured paint will be softer.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
