Author Topic: Irritating rattle developed  (Read 7502 times)
Offline 7MAT
« on: 06 June 2018, 10:01 »
My car in the last two weeks has developed an irritating rattle which seems to be coming from the glovebox area.
On smooth road its fine, but on bumpy or uneven roads I can hear it.
Done the usual and removed everything from the glovebox and passenger door, even removed the glovebox but can't see anything loose at all.
Have to be honest its driving me mad, has anyone had anything similar or can recommend anything to check / do next?
Matt
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
Offline fredgroves
Re: Irritating rattle developed
« Reply #1 on: 06 June 2018, 10:05 »
Sunglasses in the overhead compartment, by the interior lights?
Offline mcmaddy
« Reply #2 on: 06 June 2018, 10:08 »
Check the plastic trim behind the rear view mirror. It's in two parts, make sure everything is clipped together properly. Alternatively try driving with the passenger sun visor down, this can also rattle.
Offline 7MAT
« Reply #3 on: 06 June 2018, 11:06 »
I've been caught out by this already  :grin:
Offline 7MAT
« Reply #4 on: 06 June 2018, 11:07 »
Thanks, will check this next.
Offline fredgroves
« Reply #5 on: 06 June 2018, 11:18 »
Get someone in the passenger seat and get them to listen and locate the source - it can be really hard to accurately locate a rattle when you are driving and the sound can get bounced around deceiving you...
Offline dereks
« Reply #6 on: 06 June 2018, 11:42 »
Sunvisor can be a culprit.
Offline Tethias
« Reply #7 on: 06 June 2018, 12:13 »
I've got rattles from both driver and front passenger doors, very high frequency rattling from the actual door card where it meets the B pillar when closed. Can be stopped by gently pressing on the door card.
Would be worth checking its not that as i know a number of other people have had the same issue, ill be getting my local dealer to look at it when its come to the having the first oil change in a few 1000 miles
Offline Watts
« Reply #8 on: 06 June 2018, 13:53 »
My passenger side rattles occasionally, just opening it sorts it out.
Previously:
Offline mcmaddy
« Reply #9 on: 06 June 2018, 13:57 »
Sunvisor is a known issue and VW have a fix for it.
