Author Topic: Personalization menu  (Read 2007 times)
Offline Sootchucker
« on: 21 May 2018, 16:17 »
Hi all, just a quick question. If you set up a name in the Personalization menu of the new MK 7.5 with the active info display dash, is the dash supposed to display your name i.e "Hello James" or "Goodbye James", or does the name just pop up after starting to select one of the available profiles ?
Offline fredgroves
Re: Personalization menu
« Reply #1 on: 21 May 2018, 16:43 »
It comes up when you start the car with the profile name (eg mine says "Fred") and you can use the up down steering wheel controls to select a different profile if you want (eg "wifey"). It doesn't say hello or goodbye.
Offline STmichael
« Reply #2 on: 23 May 2018, 17:17 »
You can also set each driver to a key so your profile is automatically chosen on startup of the car.
GTD drivers know best!
