Author Topic: Rear Wiper Issue  (Read 4461 times)
Offline spdpug98
Rear Wiper Issue
« on: 12 May 2018, 17:18 »
Has anyone had an issue with their rear wiper, I’ve just been out driving in the rain and realised my rear wiper is not working and won’t even wash / wipe.....it works fine when I put the car into reverse but just doesn’t work if I move the lever
My car only has 900 miles on it so first time I’ve tried to use it
Offline mcmaddy
Re: Rear Wiper Issue
« Reply #1 on: 12 May 2018, 18:11 »
Never use my rear wiper ever and turned it off for reversing too. Doesn't help you any but sounds like a dodgy stalk switch.
Offline fredgroves
« Reply #2 on: 12 May 2018, 18:16 »
Have you removed the mirrors too? Might as well...
Offline mcmaddy
« Reply #3 on: 12 May 2018, 22:11 »
Totally different Fred. You could probably remove the rear wiper and never miss it.
Offline dubber36
« Reply #4 on: 13 May 2018, 07:28 »
It could be a coding issue. Lot of things on our new Tig stopped working, rear wiper included. It turned out that the BCM had a fit and needed all the coding resetting.
Offline mcmaddy
« Reply #5 on: 13 May 2018, 08:44 »
If it's working in reverse though it's probably not the bcm. A quick scan with vcds could help.
Offline a9wyn
« Reply #6 on: 13 May 2018, 09:15 »
Visibility out of my rear window in bad weather is dreadful. I suppose it's down to the hatchback design. The whole tailgate gets covered in road grime. I would be lost without my rear wiper.
Offline wantmygti
« Reply #7 on: 13 May 2018, 09:52 »
Where about are you in the south coast? I have OBD11 in Crawley area...
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline hog_hedge
« Reply #8 on: 13 May 2018, 09:59 »
This is my rear wiper now :grin:
I have 90% tints and I know just how much damage to the rear window you can cause by using the rear wiper. It’s only in horrendous weather conditions that my rear visibility is compromised and it’s no big deal if you’re driving like a normal person.
« Last Edit: 13 May 2018, 15:07 by hog_hedge »
Offline spdpug98
« Reply #9 on: 13 May 2018, 10:15 »
Thanks for the offer, unfortunately I’m over in the New Forest direction
I’ll get it booked in at the local dealers and see what they can find
