Author Topic: Replacement Number Plates  (Read 10107 times)
Offline Booth11
Re: Replacement Number Plates
« Reply #10 on: 12 May 2018, 10:17 »
Excellent Rebecca thanks for the link. Knew you'd save the day 👍. I'm assuming m.ebay.co.uk/itm/3M-x-20MM-AUTO-ACRYLIC-FOAM-DOUBLE-SIDED-ATTACHMENT-ADHESIVE-TAPE/181700778986?hash=item2a4e35dbea:g:hJMAAOSwSWJXRE6c is the same stuff??
Looks the same.  If it’s 3M foam tape it’s going to be fine. 1 roll just did both my plates, using it the entire circumference around each plate and then a series of vertical strips every couple inches along the length of the plate.  andy’s probably right, I’m not sure it’s ever coming off!  Lol.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mcmaddy
« Reply #11 on: 12 May 2018, 10:26 »
More is better  :whistle:
Offline JoeGTI
« Reply #12 on: 12 May 2018, 12:27 »
I’ve used “trim tape” that I got in Halfords for this job before and it was perfect. There was no way the plate was coming off without some brute force. About a fiver for a roll.
Offline mcmaddy
« Reply #13 on: 12 May 2018, 13:29 »
Cheers all
Offline p3asa
« Reply #14 on: 12 May 2018, 20:34 »
Thats more than a belts and braces approach :laugh:
With my kids all having private plates and wanting fancy plates at that I must change a set of number plates at least yearly.
I did what you did above Bec and bloody hell it took me a full day once to get all that adhesive off. Never again  :laugh:
Now I just use a square in each corner and 2 squares in the middle of cheap double sided number plate roll and not one has budged.
Offline kalimon
  • My other car's a van
« Reply #15 on: 12 May 2018, 20:45 »
Exactly that.
No need to overdo it. I just use 4 vertical strips and that’s probably one strip too many.
5 DR Mk 7 GTI PP
Offline 2007GTI
« Reply #16 on: 12 May 2018, 21:00 »
Re: that eBay listing, it says 3M in the title, however that refers to the length "3M x 20MM", no where in the listing does it say it is "3M" brand and if you look at the photos of the roll, the 3 and M letters are strangely not pictured together, unlike the Amazon listing which clearly shows the 3M branding.
I could be wrong, but it looks like the ebay listing is for an inferior copy, hence the cheap price.
Offline Booth11
« Reply #17 on: 12 May 2018, 21:38 »
Haha!  I wasn’t taking any chances.  :grin:
I don’t use a personal plate (can’t stand them) so once on they’re staying on.
Just use however much you feel is necessary .  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #18 on: 12 May 2018, 21:45 »
I have small screws and coloured plastic screw covers.
Looks good with the correct colour caps and permanent.
(Until the next pheasant that is..)
« Last Edit: 12 May 2018, 21:49 by GolfTi »
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline mcmaddy
« Reply #19 on: 12 May 2018, 22:10 »
It may be a copy but until it turns up I won't know if it's inferior or not. Have got another use for it if it's crap quality. I realised it wasn't a genuine 3M product when I bought it.
