Author Topic: Scratched windscreen  (Read 4334 times)
Offline clarky92
« on: 09 May 2018, 10:19 »
This is annoying the hell out of me
2 month old GTI, must have been a tiny stone or something caught in the wiper blade and has left a hairline scratch all across my windscreen. Just deep enough can feel it when running nail across scratch.
Now im guessing there is sod all you can do about it apart from replacing. But thought I would ask in case someone knows of a miracle fix?
Offline fredgroves
Re: Scratched windscreen
« Reply #1 on: 09 May 2018, 10:36 »
If its not too deep, you can buff it out. Would need the proper gear (some sort of rotary buffer and glass paste). Autoglass or similar could fix it.
Offline CHB100
« Reply #2 on: 09 May 2018, 21:48 »
Hmm? I’d have a go with à Dremel and glass polish. And probably pay £75 for new screen.
No way could I live with a scratch as you described. Impossible to concentrate on anything else.
Get sorted ASAP my friend.
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
Offline wantmygti
« Reply #3 on: 09 May 2018, 22:12 »
Would be a shame if you picked a chip which cracked and needed a new screen...🤔
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Booth11
« Reply #4 on: 09 May 2018, 23:40 »
Be careful if machine polishing glass. If not done right, you can potentially create a slight dip or hollow in the glass, a ‘fisheye’ effect which, if in your line of vision can cause distortion.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline O2Doc
« Reply #5 on: 10 May 2018, 08:11 »
Perhaps if you are using a rotary and have left it on the glass for 2 hours in the same spot. This just is not going to happen with a DA polisher.
Offline fredgroves
« Reply #6 on: 10 May 2018, 08:52 »
Sounds like its a job for an expert rather than DIY then.
I'm fairly sure the various windscreen companies offer this sort of fix for sub thirty quid...
Offline wigit
« Reply #7 on: 11 May 2018, 12:09 »
Had a similar scratch appear on mine but as I had a chip as well got it replaced, in reality I was actually impressed with Autoglass for once who did not c@ck it up
Offline clarky92
« Reply #8 on: 11 May 2018, 12:13 »
Cheers peeps
Had a proffesional out to take a look
Needs a new windscreen - just my luck!
Sorted out with national windscreens and having a genuine vw screen fitted supplied from vw 2 weeks time.
Offline fredgroves
« Reply #9 on: 11 May 2018, 14:41 »
Really? I'm fairly sure what you describe could have been buffed out!
