Author Topic: Electric window comfort down and up dilemma  (Read 17463 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 08 May 2018, 13:58 »
I bought a complete electric window regulator and motor for my drivers side front, but its only got comfort down,I have to manually push button up to go up, I tried comparing it to my old one but its got the same part number.
Does anyone know how I can tell  the difference with between the both comfort down and up version to just the down version?
I don`t make the same mistake twice... :undecided: :embarrassed:
Offline bgbazz
  • If it aint broke...I can fix it!
Re: Electric window comfort down and up dilemma
« Reply #1 on: 08 May 2018, 17:15 »
If I'm reading your post correctly, you have a Mk 3...correct? This is a very long shot, but have a look at the early Mk 4 setup and see if that might fit. The reason I'm suggesting this...my 1999 Mk 4 TDI works perfectly, both in the up and down modes. One flick for either direction and it all happens.
Good luck.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
  • Golf MK3 GTD
« Reply #2 on: 08 May 2018, 20:19 »
I don`t think there is a mk4 electric window regulator that fits on a mk3 3 I did a search on ebay and they are shaped differently than the mk3`s
Offline bgbazz
« Reply #3 on: 08 May 2018, 20:27 »
OK, just trying be be helpful.
  • Golf MK3 GTD
« Reply #4 on: 09 May 2018, 12:53 »
OK thanks all the same...
Offline SimonG
« Reply #5 on: 12 May 2018, 07:36 »
Press the button to wind the wind up and once stopped keep it pressed for 3 to 5 seconds. Then wind down in the comfort mode and then try the comfort mode on the way up.
I believe there is an element of 'programming' the window module. Has worked for me previously.
  Mk3 Anniversary GTI 16V, Mk2 GTI
  • Golf MK3 GTD
« Reply #6 on: 15 May 2018, 17:19 »
Thanks but Iv tried that already I don't know if its broken or what,someone told me it's not and that some don't have a comfort up mode...
Offline Pete le Deet
« Reply #7 on: 28 October 2019, 17:21 »
Quote from: Weekend Mechanic
Hello,
If you're still after this, I've found that the number moulded onto the circuit board cover in raised digits is a guide. F'r instance, a passenger side motor I'm looking at on fleabay has the number '114522      05  0755  20'. That 20 at the end suggests to me that it does have the "1-touch closure" available (once initialised). -21 also would, but -22 wouldn't. The drivers' side (r/h in the u.k.) is similar but with -3# numbers instead. A lot of u.k. cars have -50 or -51, which doesn't. I did have a -40 from a convertible fitted for a while, but wasn't able to close the sunroof using the 'central closure' procedure.
If you've still got that defective winding gear which has 1 t/c, then as long as it wasn't the pcb at fault you could transplant the circuit board (or the entire motor if it's working) onto the replacement winding gear.
« Last Edit: 04 November 2019, 10:48 by Pete le Deet »
  • Golf MK3 GTD
« Reply #8 on: 01 November 2019, 20:34 »
Hello,
If you're still after this, I've found that the number moulded onto the circuit board cover in raised digits is a guide. F'r instance, a passenger side motor I'm looking at on fleabay has the number '114522      05  0755  20'. That 20 at the end suggests to me that it does have the "1-touch closure" available (once initialised). -21 also would, but -22 wouldn't. The drivers' side (r/h in the u.k.) is similar but with -3# numbers instead. A lot of u.k. cars have -51, which doesn't. I did have a -40 from a convertible fitted for a while, but wasn't able to close the sunroof using the 'central closure' procedure.
If you've still got that defective winding gear which has 1 t/c, then as long as it wasn't the pcb at fault you could transplant the circuit board onto the replacement winding gear.
I am actually in in of buying another this will come in handy thanks for this!
