Author Topic: Radar sensor mk7  (Read 3919 times)
Offline mcmaddy
Radar sensor mk7
« on: 17 April 2018, 10:57 »
Can people with the mk7 radar sensor below the number plate check to see if they have any movement or play please. Was washing the car on Sunday and noticed that mine moves, only slightly but it moves. I'm wondering if it hasn't been tightened properly after my front end was damaged and then repaired. Cheers
Offline fredgroves
Re: Radar sensor mk7
« Reply #1 on: 17 April 2018, 11:00 »
Definitely shouldn't move. The alignment is really sensitive, even a few mm will have big effects on the beam coverage at 100m.
Offline mcmaddy
« Reply #2 on: 17 April 2018, 11:23 »
I haven't had any failures or warnings on the dash so it must be pointing in the right direction, just a little miffed that it hasn't been fixed properly.
Offline Sootchucker
« Reply #3 on: 17 April 2018, 11:58 »
Pretty sure mine moves a little (just a few mm) as it's only fixed to a relatively flimsy plastic bracket so is bound to flex slightly. I'll have a look at mine at lunchtime.
**update** Checked mine at lunchtime and actually it's pretty rigid. I can move the sensor a mm or so by really trying (the plastic mount flexing) but just touching it, it's pretty rock solid.
« Last Edit: 17 April 2018, 13:18 by Sootchucker »
Offline MjrSharpe
« Reply #4 on: 17 April 2018, 13:04 »
Mine has a very small amount of play in it, but only when you try to move it. I think it's just the bracket flexing as someone mentioned.
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline p3asa
« Reply #5 on: 17 April 2018, 15:43 »
My wife's moves quite a lot. I said to the dealer at service time but they just ignored it  :rolleyes:
Hers works no problem.
Offline mcmaddy
« Reply #6 on: 17 April 2018, 17:23 »
I'm pretty sure it's not fixed by a plastic bracket but a steel bracket that's attached to the front cross member. Amazing what you see when a pheasant destroys the front end haha
Offline itavaltalainen
« Reply #7 on: 17 April 2018, 17:32 »
The outer square is just trim, actual sensor sits on a metal carrier. Trim is there to cover up adjustment screws.
Mine was broken at one point (not that I noticed any impact) and needed 4-wheel alignment and new carrier, of course VW charged for this (just one of the reasons this will be my last VW for a while - it has died twice, second time now at just ten months old with massive electronics failure).
Offline mcmaddy
« Reply #8 on: 17 April 2018, 20:42 »
It might just be poorly fitting trim. I'll have a closer look at the weekend.
Offline fredgroves
« Reply #9 on: 18 April 2018, 08:57 »
I suspect this is the reason for the 7.5 having had the sensor moved... not just cosmetic...
