Author Topic: Undercarriage corrosion  (Read 2051 times)
Offline Sootchucker
« on: 09 April 2018, 08:02 »
Was cleaning the car yesterday, and I decided to give the undercarriage area a bit of a clean to get off the worst of the winter salt. I was really quite surprised to see quite a bit of corrosion on the edges of the rear wishbones, where it looks like the gloss black paint has flaked off, bottoms of the shock absorber mounts and most worryingly, quite a bit of corrosion on the rear brake back plates (around the outer edges). I could understand this if my car was 6 or 7 years old, but it's not even 2 years old until May ?
Obviously I only have the car another month or so before the GTI turns up but was wondering what to do (if anything) to prevent this happening again ? I was toying with the idea of getting some clear lacquer spray and when I detail the new car on collection, coat the major black painted parts with the lacquer to give it some extra protection.
I know this area generally can't be seen, but it still bugs me. Any ideas ?
I'll try and get some photos up later to show you what I mean.
« Last Edit: 09 April 2018, 11:55 by Sootchucker »
Offline SRGTD
Re: Undercarriage corrosion
« Reply #1 on: 09 April 2018, 09:18 »
Waxoyl (made by Hammerite) will protect it. I used this back in the 80’s to DIY rustproof three Fords that I bought from new. It did a great job.
The black parts you’re planning on applying it to just won’t look shiny like they do from the factory, as being a waxy substance, it’ll pick up road dust. If your priority is rust protection, rather than a concours show car (straight from the factory look) undercarriage, then it should do the job.
Edit; Forum member Snoopy Waxoyled his mk6 GTI from new. I think he still has the car, so might be worth a pm to him to see how it’s holding up after 7-8 years.
« Last Edit: 09 April 2018, 09:29 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline fredgroves
« Reply #2 on: 09 April 2018, 09:42 »
I don't think any car will look shiny black painted underneath after a year...
