Author Topic: Few questions about my new 7.5  (Read 4791 times)
Offline Wrex22
« on: 24 March 2018, 00:04 »
Hi got a few questions about my new gtd I picked duo yesterday   :lipsrsealed:
1. If I have the side lights on even tho it’s not dark enough for the dipped beam I get a permanent message between the dials saying ‘switch on dipped beam’. Anyway to remove this ?
2. Front parking sensors .  Do they activate automatically without going in to reverse first or pressing the button? I’ve seen it pop on on the left hand side of the infotainment display but there’s no beeps just a small visual graphic . However if I’ve gone from R to 1st they beep
3. Radio . Seem to get poor reception in fm and dab . Used to have no problems with my pervious A3 in the same areas
Offline Vwjap
Re: Few questions about my new 7.5
« Reply #1 on: 24 March 2018, 08:46 »
1: yes with obdeleven or vcds
2: mine only seems to beep when they get close to something (think it’s the yellow before the red) maybe something to do with traffic and yes after reverse they beep straight away
« Last Edit: 24 March 2018, 08:50 by Vwjap »
Offline wantmygti
« Reply #2 on: 24 March 2018, 09:21 »
1. Just leave the lights in auto and forget about them?
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline JB GTI
« Reply #3 on: 24 March 2018, 09:24 »
👍 This !
Now Gone: 3dr GTI Carbon Grey Performance Pack Dynaudio
Discover Nav Park Assist Rear Camera
Picked Up: 15th March 2014
Now Gone 3dr Golf R Lapiz Blue, DSG, Dynaudio, 19" Pretoria's, Discover Nav, Keyless, Rear View Camera
Picked Up: 1st March 2015
Now Gone Too: Mk7.5 Golf GTi Performance 5dr Indium Grey DSG Dynaudio 19” Brescia Alloys Vienna Leather Keyless Entry/Start Panoramic Roof 90% Tints Park Assist Rear View Camera Voice Activation Dynamic Lane Assist/DLA
Offline Guzzle
« Reply #4 on: 24 March 2018, 09:27 »
This is what I do with mine. Other than if it goes to the dealers, or if you need to switch on fogs, I can't think of any reason to touch the light switch. Presumably the warning is there so you don't forget to turn on dipped beam in changing light conditions. No idea why it would be there in broad daylight, but auto lights will come on long before it goes dark.
7.5 GTD
Offline fredgroves
« Reply #5 on: 24 March 2018, 10:28 »
1. Just use auto and forget it - why do you care? Alternatively if you persist with your retro ways, go into the car setup, under lighting, set the light up detection to "late" - its probably on early. That will mean its darker before it starts nagging. But seriously, leave the lights on auto and set the lighting to "early" and you'll live longer...
2. Yes, unless you've turned it off in the menus, it comes on automatically. It also comes on if anything gets close while driving. You can change all of this behaviour in the setup menu under "parking and manoeuvring"
3. Really? Mine has had the best reception of any car I've had actually...
Offline Wrex22
« Reply #6 on: 24 March 2018, 12:19 »
Thanks for your replies.   Re: radio reception- I think it maybe my dash cam causing interference  :undecided:
Offline I wanted a GTi
« Reply #7 on: 24 March 2018, 14:51 »
1) it is never too bright for low beam.
2) there is a setting to turn auto front sensors on. Think it is- car, settings, park assist, then at the top you should see auto parking sensors or some Think like that.
Offline Wrex22
« Reply #8 on: 24 March 2018, 23:45 »
They beep now! I must not of given them chance ha
Is the glove box and boot light w5w/501? Want to replace them with leds
Offline Wrex22
« Reply #9 on: 25 March 2018, 17:31 »
I can’t even open the plastic bulb cover on the glove box light :/
