Author Topic: Climatronic vents problem  (Read 2454 times)
Offline deltarikk
« on: 23 March 2018, 14:26 »
All, while driving earlier in my Gti CS heater on with air getting sent to footwell and up top, dawned on me my left hand was getting cooler and for whatever reason the centre vents had started sending cool air without me touching it? Kept getting same warmth from driver side vent and had a fiddle changing the settings to windscreen and swapping back etc but couldn't get warm air back out of centre's??
I've had a search on here but only found something via google on golfmk7.com referring to and I quote..."blocked flaps"  :whistle: ......is this likely, do these operate off sensors to open and close?
Offline fredgroves
Re: Climatronic vents problem
« Reply #1 on: 23 March 2018, 15:02 »
I've seen it happen before and suspect its down to a menu setting that says something like "automatically prevent window fogging"... have a look in the car setup.
Offline deltarikk
« Reply #2 on: 23 March 2018, 15:15 »
Thanks for that Fred I'll have a look later  :wink:
Offline mcmaddy
« Reply #3 on: 23 March 2018, 16:49 »
My centre vents always blow out cold air so I just turn them off.
Offline andyb_123
« Reply #4 on: 23 March 2018, 20:02 »
That might be the answer to my problem in another thread, where the car fogs up sometimes when you stick recirc on...!
