Author Topic: No mode button at gear area  (Read 18705 times)
Offline Plodalong
« on: 13 March 2018, 23:34 »
Hi,
Sorry if this has been covered before, but I picked up a 2016 GTI this evening, however it doesn't have a mode button down beside the gear lever. I thought all GTIs had this enabling access to adjust the settings of the car. Does the mode button on the steering wheel do the same this.
Thanks M.
Whether you think you can or you think you can't, you're probably right.
White 16 GTI PP.
Offline Carbon VW
Re: No mode button at gear area
« Reply #1 on: 13 March 2018, 23:45 »
Hi there ! Congrats on your purchase. To answer your question , no the mode button on the left of your steering wheel controls the cruise control/speed limiter only. If you do not have a mode button to the left of your gear stick then your car doesn’t have the driver profile selection (mode button) is the car a performance pack  model or the standard GTi?
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline Plodalong
« Reply #2 on: 13 March 2018, 23:46 »
Sorry it is a manual Performance Pack.
White 16 GTI PP.
Offline Carbon VW
« Reply #3 on: 13 March 2018, 23:50 »
Have you tried finding the driving mode selection through the infotainment system? Has your car got DCC?(dynamic chassis control)
Offline Booth11
« Reply #4 on: 13 March 2018, 23:57 »
Iirc Irish cars didn’t come with the driver profile mode option as standard. It had to be specced.
This is for R’s but applies to GTI.
http://www.vwroc.com/forums/topic/23183-no-mode-button/?tab=comments#comment-373823
The button on the steering wheel does not give access to driver profiles.
JoeGTI on here will probably be able to give you more info.
« Last Edit: 13 March 2018, 23:59 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Plodalong
« Reply #5 on: 14 March 2018, 00:00 »
I couldn't find anything in the infotainment system for adjusting, and no it doesn't have he Dcc.
It is also an English car.
White 16 GTI PP.
Offline Booth11
« Reply #6 on: 14 March 2018, 00:02 »
Could it have come from Ireland originally?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Plodalong
« Reply #7 on: 14 March 2018, 00:17 »
I checked the log book and it doesn't show anything about coming from Ireland and it has only ever been registered in GB.
« Last Edit: 14 March 2018, 00:31 by Plodalong »
White 16 GTI PP.
Offline JoeGTI
« Reply #8 on: 14 March 2018, 00:37 »
Rep of Ireland GTI’s didn’t (still don’t? -  not sure about the 7.5) get that Mode button unless the adaptive chassis (DCC) was spec’d.
So I guess it’s possible that it’s originally a ROI spec car. An ROI car would also originally be fitted with a KPH-only speedo although this could have been swapped for mph clocks relatively easily.
Offline Hebegeebee
« Reply #9 on: 14 March 2018, 00:42 »
Hi Joe, the 7.5 GTi’s here have the mode button even without DCC.
Picked up 03/Nov/2017 - GTi-P, White silver, 5dr., Manual with extras
