Author Topic: led boot light  (Read 2404 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
led boot light
« on: 13 March 2018, 06:07 »
hi there looking to change theboot light in my golf gtd 2013 . had a look on ebay theres so many just wondering if any one has upgraded theres and which on is the best to go for ... cheers
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline SRGTD
Re: led boot light
« Reply #1 on: 13 March 2018, 07:53 »
Yes, other forum members have. Always worth trying the forum ‘search’ function, as little mods like changing bulbs to LEDs are likely to have been done before. A search on ‘LED boot light’ found these;
http://www.golfgtiforum.co.uk/index.php?topic=278528.msg2545531#msg2545531 (reply #4)
http://www.golfgtiforum.co.uk/index.php?topic=275737.0
http://www.golfgtiforum.co.uk/index.php?topic=282666.msg2580511#msg2580511 (Reply #26)
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Talk-torque
Re: led boot light
« Reply #2 on: 13 March 2018, 13:31 »
A small point, which applies to all of the "solutions" linked above, is that replacing the standard incandescent bulb in the boot with a basic led equivalent will result in the led being dimly lit, even when the hatch is closed. Certainly not enough current draw to be a problem for the car, short term anyway, but not as it should be. I have seen suggestions that fitting a "canbus safe" led bulb will fix this, but I have no proof of this, or examples of suitable bulbs.
Roger.
Offline itavaltalainen
Re: led boot light
« Reply #3 on: 13 March 2018, 16:44 »
It will not drain the battery - unless you don't use it for months and months. The standard bulb also draws very little current when it's off but we are talking µA here for either. If you fit an error-free LED (for monitored lights - which the interior ISN'T) you'd just create quite a lot of heat when it's on needlessly.
A simple 4k7 or 5k5 resistor across the contacts will do the trick to stop the very dim glow.....
See this post:
https://www.motor-talk.de/forum/codierung-vcds-golf-7-t4316380.html?page=307#post45570786
« Last Edit: 13 March 2018, 16:49 by itavaltalainen »
Offline Arnold_Lane
Re: led boot light
« Reply #4 on: 16 March 2018, 13:03 »
Try Superskoda for boot lights as I would have thought the Octavia ones would fit the Golf.
http://www.superskoda.com/Skoda/OCTAVIA-III/Octavia-III-MEGA-POWER-LED-cargo-trunk-light-KI-R
I've used them before and they are very good and delivery is prompt.
SOLD - 67 Golf GTi PP, 5dr, DSG in Issac Blue with rear camera, keyless entry, Dynaudio, Brescia alloys & DCC.
Re: led boot light
« Reply #5 on: 16 March 2018, 17:19 »
That's about ten times the price I paid for mine..... including the modification of the bulb holder so it doesn't glim.
Offline Bungleaio
Re: led boot light
« Reply #6 on: 19 March 2018, 12:11 »
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
