Author Topic: Engine starting problems  (Read 7136 times)
Offline VW91
« on: 03 March 2018, 15:43 »
Hello!
My engine seems to be having issues starting please see the video. I am sorry about the quality.
What could it be?
1.4 TSI 122
https://www.youtube.com/watch?v=tSQypGLXyZw
Also just went back out to it and it managed to turn on. The CEL & EPC light stayed on.. the car was shaking/misfiring? and if i tried to put my foot on the accelerator it didn't do anything at all... had no throttle response.
Tried again 30 Minutes later and it started.. lights off.
« Last Edit: 04 March 2018, 16:31 by VW91 »
Offline itavaltalainen
Re: Engine starting problems
« Reply #1 on: 03 March 2018, 17:44 »
Check the ECU for fault codes; without that it's useless guesswork.
Offline VW91
« Reply #2 on: 03 March 2018, 18:13 »
Would a cheap code scanner do that for me?
« Last Edit: 04 March 2018, 13:23 by VW91 »
Offline VW91
« Reply #3 on: 04 March 2018, 13:23 »
Got a really cheap reader as i thought it was worth the £10 gamble lol
Fault: 00
Pend: 01
01/01
PO302 P
01/01
Misfire on cylinder 2?
« Last Edit: 04 March 2018, 13:51 by VW91 »
Offline VW91
« Reply #4 on: 04 March 2018, 15:56 »
I have swapped the coil from cylinder 2 to another and the fault code didn't change so it can't be the ignition coil? I also had a look at the spark plugs.
I have been told on another forum the fuel filter is a common failure? could this be it?
« Last Edit: 06 March 2018, 16:42 by VW91 »
Offline VW91
« Reply #5 on: 06 March 2018, 16:41 »
There is a noise coming from my exhaust?I will upload a video
https://www.youtube.com/watch?v=iXxL_tBblJc
Also what is this hole underneath my car?
https://imgur.com/a/T38aD
Offline joe6
« Reply #6 on: 07 March 2018, 18:16 »
The 'noise' sounds like a blown exhaust - hole somewhere and could be part of the cause of poor starting? The photo looks like the cross member on the rear suspension and if so looks like a drain hole.
Offline VW91
« Reply #7 on: 07 March 2018, 18:46 »
Yeah i think it is a drain hole also after looking on the internet.
Ill get under the car tomorrow to look at the exhaust :)
MOT is due in 2 weeks aswell  :grin:
Offline VW91
« Reply #8 on: 18 March 2018, 13:26 »
Engine misfire on a cold start. If you turn the engine off and on a couple times it does manage to start as normal.
https://www.youtube.com/watch?v=sQgpYEOnYfQ
The exhaust when it does manage to start
https://www.youtube.com/watch?v=nLC2MsIvxdY (smoke)
New plugs went in last week and the plugs in cylinder 2&3 already carbon fouled
https://i.imgur.com/JeABuKe.jpg
Plugs in cylinder 1&4 not as bad
https://imgur.com/tCUhSdm
« Last Edit: 18 March 2018, 13:29 by VW91 »
Offline joe6
« Reply #9 on: 19 March 2018, 19:11 »
I'm guessing but it could be over-fuelling because of faulty or dirty fuel injectors? That would also give a P0302 misfire fault code and cause poor starting. Worst case is worn cylinders/liners that would show up with a compression test. Hope you get it fixed soon.
