Author Topic: Golf mk3 electric window problem (solved)  (Read 4803 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 22 February 2018, 20:21 »
I could not find any information in forums to the electic window problem I was having,but this fixed my issue...
If you have tried all the obvious suggestion like split wiring in the door jams or tracking down a bad earth connection,or the regulators themselves with no luck.
This is what I did,my drivers side window would work intermittently or not at all, so I took the whole motor and regulator assembly out and unscrewed the motor/electronic one touch unit, then unscrewed the electonic one touch unit and lifted it off the motor I got out my mini ratchet and waked the relay hard 3 times, the relay from working intermittently now workes every time I know it's not the perfect solution but the circuit board is moulded to the plastic housing and can not be turned over to solder in a new relay.
I hope this helps someone out as it did for me.
Peace ✌
