Author Topic: Mk 7 GTI non/PP - all hope lost?  (Read 8747 times)
Offline fredgroves
Re: Mk 7 GTI non/PP - all hope lost?
« Reply #20 on: 07 February 2018, 09:17 »
If you were to retrofit even the OEM parts your insurance company would charge you a fortune too, because they are gits.
It seems with pretty much anything on a Mk7.x golf, spec it up front or suffer. I guess that's modern cars for you. I'd doubt if any other OEM's vehicles are any different these days.
I'd love to fit a really top notch brake set and I have thought about doing it to many cars we've owned over the years, but the cost of doing it and the extra insurance just makes it a crazy idea.
Offline MjrSharpe
« Reply #21 on: 07 February 2018, 09:32 »
"If you had ordered the PP & come from an Astra VXR with Brembos & a Drexlar diff you might have been disappointed ...
The PP brakes are the statdard "R" ones which do the job, but are cast iron sliding fist single piston & would weigh twice the ammount of those Brembos...which would be nice & light weight & at least 4 pots
& the PP VAQ is an Electro-hydraulic Front Diff Lock & not a mechanical LSD like the Drexlar....two completly different animals trying to achive the same result, but with different reactions & feel if compared side by side in the same situation...
[/quote]
The brembo brakes were great, as was the lsd. The Astra was such a heavy car though that the golf feels much more nimble in comarison. A nice set of ap brakes or something similar would be fantastic on it. Do you know if wavetrac or quaiffe do an lsd retrofit?
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline fredgroves
« Reply #22 on: 07 February 2018, 09:53 »
Google suggests either Quaiffe or Wavetrac are possible with the latter being superior...
£2500 supplied and fitted for the Wavetrac maybe?
Offline golfdave
« Reply #23 on: 07 February 2018, 09:56 »
Wavetrak do a MK7 LSD...the MK7 gearbox is the same (02Q) as the MK6 & previous, just with minor revisions
http://www.wavetrac.net/application.htm
& they do DSG versions..better than the quaife for pre-load....
Brakes...
https://www.vagbremtechnic.com/vw/golf-mk7-5g-2014-onwards/
take your pick but a good set up would J hooks.& not too big a disc to hinder alloys..
https://www.vagbremtechnic.com/front-brake-kit-4-piston-brembo-calipers-options-for-discs-bk0012/
Offline fredgroves
« Reply #24 on: 07 February 2018, 10:13 »
If you went with those upgraded fronts, would you need to do anything to the rears or are they over braked already?
Would setting up the balance be hard?
Offline MjrSharpe
« Reply #25 on: 07 February 2018, 10:50 »
Brakes...
Thank you :) I have never seen the j hooked pattern on discs before. Seems like a good upgrade and one I would definitely consider :)
Offline golfdave
« Reply #26 on: 07 February 2018, 12:08 »
leave the rears as OTT...
So long as the pistons total capacity is the same as the OEM then the balance/pressure is not affected that much....
The "R" & therefore the PP & CSS are all the same callipers....& total capacity is more then the GTI which uses the same callipers as the lower models.
So there are is a different master cylinders/servo...for the R/PP/CSS....
But so long as you stay within the OEM size fro your car then a 4 pot with correct sized pistons will be fine
« Last Edit: 07 February 2018, 12:17 by golfdave »
