Author Topic: Spare Wheel  (Read 12335 times)
Offline Restlessnative
Re: Spare Wheel
« Reply #10 on: 04 February 2018, 22:43 »
Same with mine too:
That's the one!. :smiley:
Current: Golf GTD MK7  3 door manual carbon grey.
Offline gtiaps
Re: Spare Wheel
« Reply #11 on: 05 February 2018, 15:25 »
Same with mine too:
Just like mine in the 2016 Gti...  :whistle:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline golfdave
Re: Spare Wheel
« Reply #12 on: 05 February 2018, 16:58 »
same as my 2015 build estate...
You get a "skinny" 19inch (I think) rim space saver...
You can't fit the Dynaudio sub into a smaller rim....you can fit it so the tub fits into a 17inch rim but then even with the longest screw from VW you can't locate the lot together....& you have to have the floor on high...mind you I leave mine on high....I did look into using the sub with a full width 225mm tyre/alloy......might have to revisit...
Offline WD-40
Re: Spare Wheel
« Reply #13 on: 06 February 2018, 10:56 »
I have a CS40, with Dynaudio, and can confirm I also have a space saver with the sub inside - same as in the previously posted pictures. I assume it's 19" as per my Prets.
And I'm very grateful for it too as it's already been used when I had a puncture...
Current:
2018 BMW M2
2002 Porsche 911 (996) Carrera 4
Ex:
2017 GTI Clubsport Edition 40 #645, MG Midget, Audi S4 Avant, Mercedes-AMG C63, Porsche Cayman S Sport, BMW Z4MR, Honda S2000, Alfa Romeo GTV, Peugeot 106 Rallye, Austin Mini E amongst others
Offline itavaltalainen
Re: Spare Wheel
« Reply #14 on: 06 February 2018, 17:58 »
Space saver is 18", at least the one in image above is.
Afaik the Golf came either with 16 or 18" space saver. GTD, GTI and R should have the latter. My GT had the 16", assuming that's because it came with 17" wheels.
Offline Gnasher
  • Formerly GnasherVXR
Re: Spare Wheel
« Reply #15 on: 06 February 2018, 18:43 »
I think it's mainly to do with what brakes it needs to fit over, remember you can't fit 16" rims to a PP/R.
Just a thought - if the rolling radius of the standard wheels on a GTI is the same as that of a base model (and bearing in mind how skinny a space saver is), how tall must the profile of tyre be on the base model 16" space saver. Think about a GTI (non PP) on 16's - now that's going to be a tall tyre. Then reduce the width of the rim by around a half. Now that's a high profile tyre!! I know the sidewall would be the same height, but the aspect ratio must be astronomical!
This of course assumes that they do 16" space savers and the rolling radius is the same.
As I said, just a thought...
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline golfdave
Re: Spare Wheel
« Reply #16 on: 06 February 2018, 20:32 »
From the ERWIN documents there are only two sizes of skinny spare tyre for the MK7 Golf
3.5J x 18 rim, 125/70R18 tyre
or
3.5J x 16 rim, 125/70R16 tyre
so the rolling radius is different.....
but in the ETKA list the world wide spare list has:-
6Jx15
6Jx16
6.5Jx16
But the Dynaudio sub will only fit in the 3.5J x 18 rim, 125/70R18 tyre....
