Author Topic: Installing android radio  (Read 3139 times)
Offline tomstud12
« on: 29 January 2018, 10:04 »
Hello
I'm trying to connect my golf 2010 to an android radio. I just want to ask i have this Can bus ( Can-Bus ) and this radio ( Radio ) but rather than me have to snip all the wires and connect them separately.
Are there any plugs that i can connect to the radio and do the can-Bus adapter? I seen these but these are for pioneer ( Example )
Thanks
« Last Edit: 29 January 2018, 10:08 by tomstud12 »
Offline Charliemk6
Re: Installing android radio
« Reply #1 on: 06 February 2018, 11:24 »
Most of the Android units I have seen for sale on Ebay come with the correct connectors and canbus adapter?  Pretty sure they should be plug and play?
Offline itavaltalainen
« Reply #2 on: 07 February 2018, 13:00 »
Without knowing what unit you want to fit exactly it's anyone's guess what comes with it as standard.
However you will need a CAN bus adapter (do not be tempted to just 'wire it to ignition' - otherwise you're asking for trouble), this should be platform specific. Ask the seller if a mk6 platform spec CAN bus adapter is supplied with the unit, if not get one. The seller will no doubt want to make a sale and may tell you that you can just hard wire it  :whistle:
