Author Topic: Retrofit climate windscreen  (Read 10093 times)
Offline seanng
Re: Retrofit climate windscreen
« Reply #10 on: 05 January 2018, 23:58 »
Can't see why not, but given the cost of replacement windscreen (first one I needed on my mk7 estate was 1200£ from Autoglass! - not sure how much it cost the second time round about 6 months later) it would be cost prohibitive to start with.
Probably needs high BCM, bit of wiring, relay and an awful lot of coding. Possibly activation with a code by VW, though not sure if this is something that exists.
Isn’t it covered under your insurance with a small excess fee? Just checked with my insurer and it’s £75 for replacement and £25 for repair using Autoglass!
yep all access went up to £75 when the front cameras started needing calibrations or so the windscreen fitted told me
So the excess was £75 for the screen to be replaced and calibrated?
on mine yes, but they have to check your insurance to find out, and you need to take it to one of their centres as it can’t be done on the road,
Good to know... I don’t understand why others are paying full whack when the insurance covers it?
Offline Vwjap
« Reply #11 on: 06 January 2018, 00:01 »
I think the OP wants to replace a normal screen with a heated one, and insurance doesn’t cover that,
Offline golfdave
« Reply #12 on: 06 January 2018, 10:50 »
Nobody's mentioned the fact that the OP will have to remove the HVAC control dials & fit a new set which has the button to activate the front heated screen...in conjunction with the front demist..as the far left dial is split into two face parts, front screen/ rear screen.
https://volkswagen.7zap.com/en/rdw/golf+variant+4motion/golf/2015-746/9/941-941058/
Offline Guzzle
« Reply #13 on: 06 January 2018, 11:47 »
I have the climate screen on mine and there is no physical button to activate it. It's turned on or off by going into the menu.
My Octavia was different as it had the older style heated screen with wires and this did have a physical button in the central dial.
7.5 GTD
Offline golfdave
« Reply #14 on: 06 January 2018, 12:13 »
The touch screen is the main button so to speak...
BUT with the split far left button on the climatronic the front screen also heats up with the demist function....page 288 of my estate owners manual.
So if the OP has the front screen/rear screen split face far left dial all is ok...just needs to VCDS the HVAC module...
Also hope that the wires to the main control module & the required relay are fitted....(just had a look at the ERWIN diagrams..)
« Last Edit: 06 January 2018, 12:20 by golfdave »
