Author Topic: Golf R DSG and GTI DSG  (Read 2119 times)
Offline p_adamek
« on: 03 January 2018, 12:36 »
Sorry if this has been answered before, but is the 6 speed DSG found in the R the same as the GTI?
I'm looking at getting a GTI and wondered if it could handle another 40ish bhp if i decided to chip it
Thanks!
Offline clarky92
Re: Golf R DSG and GTI DSG
« Reply #1 on: 03 January 2018, 13:02 »
The mk7 golf r and mk7 gti share the same 6 speed dsg
The mk7.5 gti uses the same 6 speed dsg
The mk7.5 gti pp uses the new 7 speed dsg
The mk7.5 r uses the new 7 speed dsg
Hope this helps!
Offline Sootchucker
« Reply #2 on: 03 January 2018, 13:23 »
Although from a spec point of view the 7 speed DSG from the 7.5 GTI PP and the 7.5 R might be similar (don't know if they are) surely they must be different units as the R model has the transfer box for the AWD to the rear Haldex unit, and the 7.5 GTI PP unit has the special mechanical LSD installed.
Not sure if they are similar at all really ?
Offline fredgroves
« Reply #3 on: 03 January 2018, 14:17 »
I guess part numbers are how you'd find out for sure if they were 100% identical.
As for it handling extra power, from what I've read the DSG box seems to be able to cope with a stage 1 tune far better than the manual. With manuals you read a lot of about clutch slip after stage 1 is applied.
That's only a strictly amateur opinion btw, based on reading this and other forums a lot over the last few years.
Offline Booth11
« Reply #4 on: 03 January 2018, 14:44 »
As above.  Lots of reports of clutch slip after stage 1 (see VWROC forum) and plenty of threads/posts about the weak (chocolate) clutch and better upgrades. Worth looking in the modifying sections of forums to get the bigger picture.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline kelvyn29
« Reply #5 on: 03 January 2018, 15:24 »
My GTI PP Manual with only 14000 miles NO mods clutch has started to slip.
Going back to VW in the next week to look at
