Author Topic: Footwell lights on a GTTDI  (Read 3377 times)
Offline Da21982
« on: 17 December 2017, 20:09 »
Can any one shed some light (no pun intended) on the issue I'm having. I have just purchased a 64 plate GTTDI bluemotion tech. I have the ambient lighting on the 2 front doors, puddle lights and folding mirrors I have foot well lights installed on the front but I don't have them installed on the back is this standard.
Thanks
« Last Edit: 17 December 2017, 20:13 by Da21982 »
Octavia vrs mk3, Golf mk4 GTTDI, Golf MK7 GTTDI
Vag master Tech with vcds
Offline Watts
Re: Footwell lights on a GTTDI
« Reply #1 on: 17 December 2017, 20:11 »
No footwell lights in the rear, it is possible to fit them though if you are handy with car electrics.
Previously:
Offline Da21982
« Reply #2 on: 17 December 2017, 20:14 »
Don't have an issue fitting them that's the easy part I had a mk 3 vrs fitted a kit to that about 4 year ago I'm just curious really as to why their in the front and not the rear.
Offline Watts
« Reply #3 on: 17 December 2017, 20:20 »
No idea but would guess cost. Doesn't bother me.
Welcome to the forum btw, what spec did you go for?
Previously:
Offline Da21982
« Reply #4 on: 17 December 2017, 20:23 »
Thanks for the welcome, I had a mk 3 vrs I now have a GTTDI bluemotion tech only had the car 3 days its in for a map on Tuesday ill be looking for some wheels, coilovers or air depending or prices and rear spoiler only plan on keeping it for a year maybe 2 and then ill be looking for a R or worse case GTD..
Offline Sootchucker
« Reply #5 on: 18 December 2017, 16:34 »
As others have said, none of the Golf models come with rear footwell lighting. Having said that, the cut outs for the lights are there in the seat frame lower squab base. I added them to mine with a no cut plug and play harness from Kuaftec.
Likewise, the active door warning lights have never been fitted as standard to the MK7 Golf, but again with a little bit of electrical knowledge, it's fairly straightforward to add them :
Offline Da21982
« Reply #6 on: 20 December 2017, 13:09 »
Looking at getting the rear foot well lights from boltsports. We’re did you get the door entry lights from and
If memory serves me right they just need wiring in and coding to door control units.
