Author Topic: Freewheel + start/stop on DSG Question  (Read 11660 times)
Offline clarky92
Re: Freewheel + start/stop on DSG Question
« Reply #10 on: 18 December 2017, 18:11 »
I can confirm on my 7.5 GTI in ECO the engine will switch off and coast. I use this daily . A small e will appear on the AID instead of a gear selection.
Offline Sootchucker
« Reply #11 on: 18 December 2017, 19:16 »
Are you sure it’s actually switching off, not just dropping down to idle revs (circa 700-800rpm), as that’s what mine does when I get the small “E” appearing in the MFD ?
Offline itavaltalainen
« Reply #12 on: 18 December 2017, 19:23 »
It does actually switch off in facelift. I know for sure on the 1.5 TSI.
Offline maxie
« Reply #13 on: 18 December 2017, 19:32 »
same here :)
Offline JoeGTI
« Reply #14 on: 18 December 2017, 20:09 »
The engine switches off? Wow. I thought the coasting thing was bad enough but that takes the biscuit. I detest that Eco mode nonsense and the start/stop thing - hence I've disabled it.
Offline wantmygti
« Reply #15 on: 18 December 2017, 20:35 »
My CS will drop the revs to tick over and coast, but I don’t need to cycle though the driving programs each time I start the car.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline clarky92
« Reply #16 on: 18 December 2017, 21:26 »
The engine completely cuts out on my 7.5 GTI
Offline Don76
« Reply #17 on: 19 December 2017, 15:24 »
Sounds like only the petrol engines switch off. My facelift GTD DSG coasts at just over 500rpm but never switches off completely
Offline maxie
« Reply #18 on: 19 December 2017, 15:28 »
yours must be set differently to mine, when driving in eco looks E3 etc when cruising/freewheeling it turns to E with an eco sign next to it (on the left)and the revs drop to 800rpm but still it is not turned off. the only time it does turn off is at a full stop.
Offline hog_hedge
« Reply #19 on: 19 December 2017, 22:15 »
My 7.5 completely shuts off too but only on long downhill stretches, I thought the car had given up the ghost the first time it happened.
