Golf mk4
Wazzzer
Heaters and temp gauge
Topic: Heaters and temp gauge (Read 4839 times)
Cuddy
Just got here
10 December 2017, 15:59 »
Hi everyone
My temp gauge sits at 90 at idle(heaters are hot) but drops when driving(heaters go cold)
I have changed the timing belt water pump & thermostat & coolant sensor with vw parts but it's still the same 😠 the car doesn't overheat
Thanks mark
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Heaters and temp gauge
10 December 2017, 16:50 »
Replaced the housing?
Does radiator hose get warm before it reaches mid-80s (read measuring blocks with VCDS as gauge is not linear).
Cuddy
Just got here
10 December 2017, 16:59 »
Sorry I forgot the to say the housing was replaced at the same time. The radiator hose get warm as they should do but I don't have vcds thanks
itavaltalainen
10 December 2017, 17:03 »
Radiator return hose should NOT get warm until engine has heated up to around 85-90 degrees. If it does before then I would think thermostat is still duff, happens quite often. Get one from Behr.
sharki786
GOT BOOST??
22 December 2017, 19:37 »
Was this a genuine thermostat or after market? As the after market1s are bogus
*****MK3 Anniversary*****
*****MK4 GTI T*****
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
23 December 2017, 19:48 »
Just as a side note VW don't make thermostats so a "genuine" thermo is still made by another company. I have used a Meyle thermostat in mine after the original failed and after 3 months of driving, so far so good
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Golf mk4
Wazzzer
