Author Topic: Anyone wanting to disable keyless opening  (Read 33663 times)
Offline ar899
Re: Anyone wanting to disable keyless opening
« Reply #40 on: 19 November 2019, 11:12 »
Just had a quick scan through this thread. In a 7.5 GTI/GTI Perf with keyless, is disabling the keyless system as simple as locking the car and then pressing a button on the door handle within 5 seconds? Or am I missing something?
Offline SRGTD
« Reply #41 on: 19 November 2019, 11:40 »
I don’t have keyless bit there’s a simple way to find out; why not just try it.
If you try opening the car door using the normal keyless entry method after you’ve followed the guidelines to temporarily disable it and you can’t open the door, then you’ll know it’s worked.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline ar899
« Reply #42 on: 19 November 2019, 11:42 »
Thanks SRGTD - I don't have one yet to try though......
Offline CookieMonsterGTi
« Reply #43 on: 19 November 2019, 11:52 »
Yes, thats it.
Only stays this way until its unlocked then you have to repeat the process next time you lock if you want it to behave that way, otherwise operates as expected.
Current:
Dark Moss Green GTI Edition 50, Performance Pack, 19” ‘Warmenau’ Black Alloys, Harman Kardon, Panoramic Sunroof, Area View
Gone:
Pure Grey GTI TCR 5 Door DSG, 19" 'Reifnitz' Alloys Including DCC, Climate Windscreen, Panoramic Sunroof, 90% Rear Tinted Glass
Offline SRGTD
« Reply #44 on: 19 November 2019, 11:58 »
I’ve read on other VAG forums (VWROC.com, Uk-polos.net, seatcupra.net) of owners with keyless entry trying the temporarily disabling procedure and it’s worked.
Don’t know exactly when VW introduced the disable function on the Golf, but if you’re considering buying a used mk7.5, if being able to disable keyless is important to you from a security perspective, you could always try the disabling function on any car you go to view before buying. If you’re considering a new GTI, then the functionality should exist.
Offline ar899
« Reply #45 on: 19 November 2019, 13:21 »
Thanks both - I'm considering a new/nearly new GTI so will try that on any I'm looking at. Assuming that works and I set it like that at night, then I don't have to faff about with a faraday box etc.?
Offline Talk-torque
« Reply #46 on: 19 November 2019, 14:07 »
It is - You lock the car with the fob button, then touch the outside of the door handle, where you would to lock it keyless, and it will remain locked until you unlock it with the fob. I use this in most public spaces and overnight. It’s nice to have that option.
Roger.
Offline OldAnd Comfy?
« Reply #47 on: 19 November 2019, 15:53 »
Just tried this on mine and it works.  So I now don't need to keep putting the key in a Faraday pouch. :smiley:
MY2019 Golf GTI Mk7.5 Performance DSG in Pearl Black, Seville Wheels, Reversing camera and performance stripes.
Offline Andy198
« Reply #48 on: 19 November 2019, 18:08 »
I just wish there was a way to disable keyless in the Car Settings, so that it always required the fob to unlock. Although once you know the 'trick' its effortless to do it I suppose.
GTI PP Mk7.5 with DCC, Sunroof, Brescias / BBS SR & 90% Tints
Offline buddfridge
« Reply #49 on: 19 November 2019, 19:20 »
A quick warning, yes this works but occasionally on mine the doors are open even when the car looks locked ( mirrors folded) after using the keyless function, I haven't worked out if its timing or possibly because I have passengers closing doors after mine, so always check.
gti pp manual white 5 door
