Author Topic: Sliding back end  (Read 4243 times)
Offline MJE
Sliding back end
« on: 28 November 2017, 22:32 »
Anyone experience their gti mk6 sliding out on tight corners? Happened a few times now on left and right handers on country roads - treads are good - could be late braking but wondered if the ESP being on/off helps
Offline joe6
Re: Sliding back end
« Reply #1 on: 29 November 2017, 10:37 »
Not experienced this. Under normal driving the suspension is set up for the front end to go first as it is assumed that this is easier to control by lifting off and is why tyre fitters will often put new tyres on the rear so the front goes first. ESP on reduces the skid/slide risk but if you are pushing it then road and front and rear tyre conditions and pressures will play a part. There is also a minimum speed when the systems operate.
Offline o`Neil
« Reply #2 on: 29 November 2017, 10:41 »
Slow down  :wink:
Offline itavaltalainen
« Reply #3 on: 29 November 2017, 17:25 »
sh!t cheap tyres? Or just really old ones?
Offline RedHP
« Reply #4 on: 30 November 2017, 21:20 »
Slow down  :wink:
 :rolleyes:
Mk6 GiT since birth in 2010
YNWA
