Author Topic: Help me mk6gti  (Read 3347 times)
Offline Catalinr32
Help me mk6gti
« on: 26 November 2017, 21:03 »
Hello. I have a smal problem with my mk6 gti 2009 manual gear box . when I try to go on a very strong start, changing the 2nd gear remains stuck as if the gas does not come .. 1gear is very brutal is i normal... that's only when I'm very sporty .. if I use the normal car it's all normal ... in other words I can not have a very brutal launch control because the second shift is dead. If i change a 2shift before 5-6000rmp all is ok ... so : I'm stop . I'm going to force 1shift up to the maximum same like a (brutal lunch control) push the clutch to change 2shift, go in 2shift and it's all stuck ... the car is not accelerating. The gear box is ok . All work perfect if i don t go in a max rmp with 1shift.
Pls help me. Thank you .
