Author Topic: My new GTI PP nearly stolen. Anybody recommend best security  (Read 19107 times)
Offline fredgroves
Re: My new GTI PP nearly stolen. Anybody recommend best security
« Reply #40 on: 29 November 2017, 11:17 »
And use the emergency key thing only instead?
I wonder if the normal remote key from non-keyless can be used? ie does the car still have that hardware in it? If so, you could get a keyfob and code it?
No I mean use the key fob buttons to lock and unlock the car and the keyless part only work when the car is unlocked.
Does keyless also have lock and unlock buttons? I have never seen one...
Offline JoeGTI
« Reply #41 on: 29 November 2017, 11:22 »
The keyfob is exactly the same whether the car is keyless or not.
Offline fredgroves
« Reply #42 on: 29 November 2017, 11:29 »
Should be possible to disable the proximity unlock function then...
Offline I wanted a GTi
« Reply #43 on: 29 November 2017, 11:35 »
I shall look into it later with my trusty OBDeleven. Be prepared for a thread starting later titled I've fecked up and can start my car :whistle:
Offline kalimon
  • My other car's a van
« Reply #44 on: 29 November 2017, 13:54 »
:laugh: :laugh: :laugh:
5 DR Mk 7 GTI PP
Offline fredgroves
« Reply #45 on: 29 November 2017, 14:09 »
A little bit of Google-fu suggests "disconnect Kessy module (ID 05) from installation, DISABLE in gateway"
« Reply #46 on: 29 November 2017, 15:09 »
« Reply #47 on: 29 November 2017, 17:29 »
Have a look here if you want a walk through of how to turn keyless off.
http://www.golfgtiforum.co.uk/index.php?topic=282638.0
